Missing plugins in 4.8
artd3Dartd3D Posts: 165
Is anyone else missing their plugins?
I installed garibaldi and keymate via DIM and my plugins do not show in
about plugins,
I can see them in the plugins directory, but not in Daz 4.8
Any suggestions as to what I am doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 111,326
    Both are present for me.
  • BeeMKayBeeMKay Posts: 7,019
    about plugins,
    Did you maybe install the Beta version accidently?
  • artd3Dartd3D Posts: 165
    No, I deleted the beta version and installed the new version with DIM.
  • FirePro9FirePro9 Posts: 456
    I installed DAZ3D 4.8.0.55 Pro 64-bit edition today and now my Reality V4 rendering editor is missing. It shows up as a registered plugin but is not visible, even with different workspace layouts Reality renderer does not show up for me.
    Per DAZ Tech Support:
    "The developer of Reality has not updated there plugin to run in DAZ studio 4.8. This means unfortunately that Reality does not work in the latest DAZ studio."
  • PlatnumkPlatnumk Posts: 682
    This it totally incorrect, Reality works perfectly with DAZ Studio 4.8 Pro.
    1st of all I would un-install Reality and re-install (make sure Studio is NOT running when un/re-installing Reality)
    Next I would check and make sure it appears in 'About Installed Plugins'
    Then check the Render Menu for 'Reality Render Editor'
    If you still can't get it to work then I would suggest that you take a look/post over at the Official Reality for DAZ Studio forums as Paolo the creator of Reality often visits and post there.
    http://forum.runtimedna.com/forumdisplay.php?322-The-Official-Reality-for-Daz-Studio-Forum
    Hope this is of some help.
    Thanks, yes already tried all of the above and no joy. It appears that it works perfectly for some and does not work at all for others....perhaps depends on OS. Regardless, given that a significant new version of Reality is due in a few weeks (hopefully), I can completely understand why Paolo would not want to waste any time on this issue. I will be patient as I am certain the new version of Reality will have to work with DAZ 4.8.
  • pammartin52pammartin52 Posts: 10
    I'm not at my PC so can't check the details, but when I upgraded from the Beta to full, Reality wasn't working. I checked the Program Files folder and the plugin was in a different folder from DAZ, I just moved them to the DAZ folder and it worked.
    As I said I'm not on my home PC to double check where I moved it from and to, but it might be worth a look?
