mcjDropToTerrain - mcjDropToTerrain2 - Daz Scripts drop objects to terrain
mCasualmCasual Posts: 4,607
edited March 2022 in Freebies
so here you see the Bobverse island, and 64 trees which were randomly duplicated using the Send-In-The-Clones script by draagonstorm
draagonstorm posted on ShareCG ( i think ) a script that uses ( after asking me ) my old mcjCollider plugin to drop the clones to a terrain
but since that solution doesnt work for MAC users, i'll write a script.
As long as the terrain is, say, under 60000 polygons, the slowness of this script should not be too painfull
if it works or doesn't work for you, please leave a short comment below
https://sites.google.com/site/mcasualsdazscripts5/mcjdroptoterrain
and if you dont seem to be able to download the zip package from that page
then here's a direct link to the zip file
i cant be sure this link will remain valid forever tho
https://sites.google.com/site/mcasualsdazscripts5/mcjdroptoterrain/mcjdroptoterrain.zip?attredirects=0&d=1
We Present mcjDropToTerrain2 (2022)
i worked in collaboration with TugPSX for this Upgrade
1920 x 1080 - 906K
932 x 760 - 128K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited January 2015
    first test results
    5.8 seconds to drop 10 trees on a 12000 facets terrain
    ( with the mcjCollider plugin it would probably be 100 times faster but hey )
    second test results
    50 seconds to drop 64 trees on a 12000 facets terrain
    i will improve the "planting" depth control and precision
    1920 x 1080 - 743K
    here you can see there will be a "planting depth" parameter
    in this case the origin of the tree is placed 40 cm below terrain level
    the trunk diameter is about 40 cm
    1920 x 1080 - 777K
    unfortunately clones of imported .obj nodes, seem to have the same node names and the same material names, which causes mcjTeleBlender to "gamma-fix" the material 64 times, making the green trees pitch-black
    so i had to turn off GammaFix in mcjTeleBlender to render this
    ( i thought that the "rename nodes" option took care of this but apparently not always )
    1920 x 1080 - 327K
    edited January 2015
    expected release is Saturday Jan. 17th
    it will work like this:
    - select all the nodes meant to be dropped-to-terrain ( the trees )
    - also select the terrain node(s)
    - start the script
    - from the list of nodes, select the ones that are terrain nodes
    - specify how deep to plant the trees
    - press the doit button
  • rksrks100rksrks100 Posts: 49
    Thanks again for all this work Casual. It's really appreciated. Looking forward to testing out the script on Sunday :) But no pressure...enjoy your weekend !
  • DraagonStormDraagonStorm Posts: 748
    Thank you Casual :)
  • KeryaKerya Posts: 10,943
    Looks wonderful!
    edited January 2015
    the user interface
    still on-track to post the script today
    at least the DS4.5+ version
    the version for DS 1, 2, 3 will follow
    in this case you could also drop boats to the water-plane
    since it's 1 of the 2 "terrain" objects
    and i realized just now, it means i have to give options related to how thorough the ray-collision search must be
    meaning, if i hit the water plane, it's not a good reason to place the tree on the water plane
    i have to go through the mountain/terrain facets that may be higher
    554 x 554 - 151K
    1280 x 540 - 164K
    448 x 590 - 151K
    1128 x 644 - 400K
    edited January 2015
    looks like the version for DS4.X is ready ! yay
    ( 4.5 and up )
    preferably download it from the bottom of this web page
    by clicking on the blue down-arrow thumbnail/link
    1920 x 648 - 322K
    HI Casual,
    Just to let you know, my initial tests to use the script in DS4.6 have been successful. Can't thank you enough for providing this ! Just for your information, the icon that is appearing in the menu section indicates DS1, DS2 even though the script is working fine thus far in DS4.6.
    edited January 2015
    rksrks100 said:
    HI Casual,
    Thanks !
    * Update * Update * Update * Update * Update * Update * Update * Update * Update * Update *
    the icon/thumbnail image has been corrected
    it reflects the fact that this is the version for DS4.5 and up
    preferred way to download the install package :bottom of this page
    direct link to the zip file - not guaranteed to remain valid - version for DS4.5 and up only
    the other versions for DS1,DS2 amd DS3 may come out today
    Note: this script is meant to drop down objects and figures onto 1 or more objects,
    later this spring i'll probably have a more universal script closer to what mcjCollider does
    91 x 91 - 13K
    edited January 2015
    presently writing/testing the Daz Studio 1, 2, 3 version of the script
    also note that i will most probably post a bug-fixed version of the DS 4.7 version
    ( because it presently functions in a fast but imprecise mode )
    1920 x 800 - 694K
    1920 x 1080 - 749K
    1920 x 1080 - 591K
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    Awesome, you just ticked off a major feature request for me. Thankyou!!!
    I didn't have any issues running the script on my Mac running OSX10.7.2 & Daz 4.7.0.12.
    The script loaded fine for the trees both above or below the selected ground terrain.
    I used trees of varying sizes and locations in two lots, the tree mesh is quite high poly to.
    First lot of 32 trees took 4mins 12
    Second lot of 16 trees took 3 mins
    Here is a quick render of the result.
    700 x 769 - 182K
    edited January 2015
    * update * update * update * update * update * update * update * update * update *
    January18th 2015 9:30 PM - the ds4 version was fixed to prevent the "fast" mode which was fast but prone to errors
    January18th 2015 9:18 PM - now a version for DS1/DS2 and one for DS3
    in case you're interested
    the fast mode
    which, for now, can only be enabled by manually changing the 'bFast' variable ( so this is for coders )
    will stop as fast as possible to search for the surface of the terrain
    so if your terrain is a water plane partly covered by a mountainous terrain
    and the script "hits" the water surface, the tree will be placed there
    the script wont look any further
    594 x 226 - 86K
    yay!
    next spring, maybe before that i will add something to the script to accelerate this greatly
    (called a Bounding volume hierarchy ) http://en.wikipedia.org/wiki/Bounding_volume_hierarchy
    and make this "collision detection" tool more versatile
  • barbultbarbult Posts: 27,534
    It isn't working for me. Even though I selected 0.0 depth, it is dropping all items below the surface. I first tried with a landscape ground prop that had rolling hills. When that didn't work as I expected, (i.e. dropped below ground), I tried a flat terrain. It still dropped below ground.
    I downloaded it today. The version I have is mcjDropToTerrain.dsa dated January 18, 2015. I am running DS 4.7.0.12 on Windows 7 64 bit.
    2000 x 1244 - 2M
    820 x 433 - 24K
    edited February 2015
    the script drops the origin of tree to the ground
    not the lowest point of the tree, unless they are at the same location
    the origin of the object is where you see the red/green/blue arrows
    there's many ways to compensate
    1 - say your tree is 300 cm tall and the origin of the tree is midway, at 150 cm
    then tell mcjDropToTerrain to use an offset of -150 ( minus 150 cm )
    2 - create a null node, place it at the base of the tree, parent the tree to the null, drop the null-node to the terrain instead of the tree
    3 - use a script that can change the location of the tree's origin, and move the origin to the base of the tree
    DeltaX15's MoveOrigin script
    mcjChangeOrientation
    4 - move the tree to Y=0 level, export it as an obj, delete the tree, import the obj tree
    5 - Go in Daz Studio / Tools / Joint Editor, move the origin to the bottom of the tree
    Note that i will probably post very soon a revised version of the script that, as an option, does drop the bottom of selected objects to the ground
    850 x 720 - 113K
  • MilosGulanMilosGulan Posts: 1,993
    I am waiting for it then and will have to try to see how it works.
    Thanks for the explanation and workarounds. The new version sounds like it will solve my problem perfectly. I'll watch for it.
    edited March 2022
    Hey Long Time No See ! 2015
    364 x 364 - 24K
    932 x 760 - 128K
    edited March 2022
    dropped some balls on this 'terrain' with and without the terrain being in hi-res subDivisions ( excellent song by RUSH )
    1891 x 1154 - 145K
    905 x 1073 - 64K
  • Faeryl WomynFaeryl Womyn Posts: 3,779
    This is great, never got a chance to use the original, though plan on giving it a go this time around. Now to find the other scripts I need to reinstall on a new computer lol
  • nakamuram002nakamuram002 Posts: 823
    edited March 2022
    mCausal:
    What are the differences between mcjDropToTerrain, mcjPlaceUnder, and mcjDropToTop?  They seem to perform the same function.
    Post edited by nakamuram002 on
    edited March 2022
    the 2 others only see the bounding boxes of the terrain and dropping objects
    mcjDropToTerrain finds the one facet among the thousands of terrain facets that lies right under the falling object and it moves the dropped object(s)  onto that facet
    with  mcjDropToTerrain2 you can also make the dropped object sink deeper in the terrain
    Promo drop to terrain
    nakamuram002 said:
    mCausal:
  • khorneV2khorneV2 Posts: 160
    awesome and very usefull as usual yes
    nakamuram002 said:
    mCausal:
    Thanks mCasual!!  That is what I needed to know.
