Render size setting
In the new 4.7 I have no idea how to make my render size bigger to what I want.
Why cant things be left as they were!!!
  • srieschsriesch Posts: 4,243
    In the Render Settings pane, click on General, then change the "Pixel Size (Global)" parameter to the desired width and height dimensions.
    602 x 460 - 40K
  • edited December 1969
    Thankyou for your quick reply. It wont do it. stuck on 591. I type in 2500 but it just goes back to 591.
    Not sure if this is what you are seeing, but remember that if you have "Constrain proportions (Global)" set to On, when you type in one of the two Pixel Size fields, it will automatically adjust the other one (after you hit enter or leave the field) so that the proportions remain the same (so you don't have to do the math yourself if you want to rescale the image but still have it match the relative width/height of your monitor/paper).
    If that's what's happening, set "Constrain proportions (Global)" to Off, type in your two values, then set "Constrain proportions (Global)" back to On when you are done.
    I tried that. Switched it off and the numbers wont change no matter how I try. Switched it back on and they still wont work. Thankyou for trying to help.
    It was so easy to do in 4.6 and this is very difficult.
  • Richard HaseltineRichard Haseltine Posts: 111,399
    Please post a screenshot of the General section of your Render Settings pane.
  • WhiteFoxWhiteFox Posts: 94
    Also make sure you have 'Dimension Preset (Global)' set to 'Custom' and not 'Active Viewport'
    1388 x 770 - 383K
    Thankyou Charlie. That worked perfectly. It has changed the size. :-)
    No problem. I had that same issue before so I figured that was what it might have been. Happy rendering ;-)
    I thank you too! I'm struggling to learn Daz Studio and feel so lost :-)
  • My question was answered I came to the post to get an answer and I got. Everyone is awesome in this thread I had been racking my brains on this and Charlie solved it amen. I am back to trying to learn how to work with Daz Studio. I now have the patience to learn now. Because it really takes patience to learn.
  • My question was answered as well. I kept wondering how to get larger final renders thanks to all.
  • I noticed they added picture size settings and aspect ratios to individual cameras now, and those override the general render settings, so if you are using an environment with pre-made cameras and the render settings do not effect a camera that's the reason.  Pretty cool, it means you can have a render setting per camera if you want to, you don't need to reset the whole scene when you change a camera.  Helps with comics where all the pictures may not be the same size.
