Auto-fitting hair to Genesis
marcoiomarcoio Posts: 45
When I auto-fit hair to Genesis, I have the ugly creases that you can see in image on the right (this is Valens Hair made for V4, but same effect occur with other hair, also with the ones made for Genesis 2 Female).
Now I found that, if in the auto-fit dialog I select “Unknown” instead of the figure for which hair were made, strangely enough not only DS4.6 fits correctly the hair to Genesis, but it doesn't produce creases, as can you see in image on the left.
792 x 595 - 30K
  • Richard HaseltineRichard Haseltine Posts: 111,438
    The creases would be the result of the way the system works out what needs to be moved to match the old shape to the new shape. If there's no old shape then there are no transformations, which is probably acceptable with most hair.
  • marcoiomarcoio Posts: 45
    Well, this makes sense... Thanks!
