Change Environment Type
DraagonStormDraagonStorm Posts: 748
How would I get the Environment type (None or Backdrop) and change it?
When I do a Scene.getBackdrop().clear(); it set the Environment Type to None, and I need to set it back to Backdrop.
Post edited by DraagonStorm on
  • Richard HaseltineRichard Haseltine Posts: 109,149
    edited November 2014
    Using Rob's standard code-crawling, one approach (though there's probably a better) might be:
     var paneMgr = MainWindow.getPaneMgr();
     // if successful, get the Content Library pane
     if ( paneMgr ) {
      var env = paneMgr.findPane( "DzEnvironmentPane" );
      // if successful, get the current container (folder or category)
      if ( env ) {
       // for ( item in env ) {
        env.noneSelected( true );
    to clear the backdrop and
     if ( paneMgr ) {
      if ( env ) {
        env.backDropSelected( true );
    to set it on.
  • rbtwhizrbtwhiz Posts: 2,485
    The API for the Environment pane will change.
    The Render To Backdrop sample shows how to set the backdrop.
    -Rob
    Post edited by rbtwhiz on
  • DraagonStormDraagonStorm Posts: 748
    -Rob
    I tried the Render to BackDrop, and that's when I discovered that when you clear the backdrop, that sets the Type to None. I you no longer see the backdrop. You have to physically go Windows->Panes-Environment and set the Type back to BackDrop...
    I want to be able to set the type to BackDrop with code, or at least check what the type is.
    // Get the backdrop for the scene
    var oBackdrop = Scene.getBackdrop();
    // Make the backdrop visible
    oBackdrop.visible = true;
    // Get the image manager
    var oImageMgr = App.getImageMgr();
    // Get an image
    var sImage = String("%1/../Pictures/Sample Pictures/Desert.jpg").arg( App.getCommonUserDocumentPath() );
    var oImage = oImageMgr.getImage( sImage );
    // Set the backdrop image
    oBackdrop.setTexture( oImage );
    -Rob
    Thank You! oBackdrop.visible = true; worked!
    // Get an image
    -Rob
