mcjQuad Plate - Morphing Mechanical Prop - 4 holes squarey plate
the holes will be movable
their radius adjustable
the many corners will be sharpen/unsharpen'able
the width/height/dept will be totally adjustable man, or woman if you are one
30 material zones,
"box" UV layout done using my free script mcjBoxUV
in fact it will be so morphable you will even be able to make a round 4-holes button ( 3000 polygons per button though )
https://sites.google.com/site/mcasualsdazscripts4/mcjquadplate
800 x 600 - 292K
1248 x 640 - 368K
1248 x 784 - 587K
1248 x 784 - 437K
800 x 600 - 197K
Post edited by mCasual on
almost ready
the morphs:
Radius int 1
Radius int 2
Radius int 3
Radius int 4
Sharp Ext Top 1
Sharp Ext Top 2
Sharp Ext Top 3
Sharp Ext Top 4
Sharp Ext Bottom 1
Sharp Ext Bottom 2
Sharp Ext Bottom 3
Sharp Ext Bottom 4
Sharp Int Top 1
Sharp Int Top 2
Sharp Int Top 3
Sharp Int Top 4
Sharp Int Bottom 1
Sharp Int Bottom 2
Sharp Int Bottom 3
Sharp Int Bottom 4
Left
Right
Back
Forth
Up
Down
Radius ext 1
Radius ext 2
Radius ext 3
Radius ext 4
X Hole 1
X Hole 2
X Hole 3
X Hole 4
Z Hole 1
Z Hole 2
Z Hole 3
Z Hole 4
ready !
- Update - Update - Update - Update - Update - Update - Update - Update -
new version with object normals flipped
this solves the all-black-render issues using advanced shaders like the cartoon shaders
it also probably solves inverted bump/normal/displacement issues
