BluEcho's V4 Merchant Resource- modified and back online!
Lissa_xyzLissa_xyz Posts: 6,116
edited September 2014 in Freebies
BluEcho has kindly given me permission to put her previous V4MR back into redistribution.
Resource may be used for commercial and non-commercial projects.
http://www.sharecg.com/v/77662/view/11/Poser/BluEchos-V4-MR-modified
Default promo is fine, but the 3 others are NSFW.
It's quite a doozy depending on your connection. It's about 129MB.
1000 x 1200 - 1M
Post edited by Lissa_xyz on
  • SixDsSixDs Posts: 2,384
    Thank you, Vaskania. And, of course, a thank you to BluEcho for making it available in the first place and allowing you to re-up it.
  • JotaerreJotaerre Posts: 37
    Thank you Vaskania, already bookmarked it for download later.
  • carrie58carrie58 Posts: 4,171
    Slight problem ,downloaded the zip and it's empty ......
    What the.. ok that's strange. I'll reupload and see if that fixes things. You're the first person to have mentioned it. Thanks!
    /edit
    I've reuploaded it and it seems to be working now. Please try again and let me know.
    Server errors.
    Contrary to whatever, that site does not like large files. Might I recommend Deviant Art?
    edit to add that after several attempts the server worked and the item was downloaded successfully.
    thanks to you both :-)
    Post edited by patience55 on
    I may start doing that for large files, and put a text file as the download on ShareCG with the download link in both the text file and the description.
    /edit
    Idon't know what's going on but this is what I get(took a screen shot) and when I hit download it is done in a second
    1920 x 1080 - 191K
    Thank you that worked .
    Yay! Enjoy!
    Very strange that some people were having difficulties. It must have been a traffic issue or something on the server side. I just read this and it sent me scurrying to check my download since I hadn't done anything with it yet, and it was fine - whole thing, no problems, and I must have been one of the first to download it. Weird.
    (Gee, you don't think I took the only copy, do you? :) )
    Post edited by SixDs on
    Yep it's all your fault .......:cheese:
    Actually it's neither strange nor unheard of, a problem at some websites more so than others. With sharecg.com as much as we all love the website, large files are a problem there even for uploading. {and that's following all the required protocol}
    An empty zip can mean that the website is way too busy to handle all requests.
