EmotiGuy Brain?
MJ007MJ007 Posts: 1,718
edited September 2014 in The Commons
I am in need of toon brain and was wondering if anyone happened to see (or would be willing to create) a toon brain using EmotiGuy?
-MJ
Post edited by MJ007 on
  • Charlie JudgeCharlie Judge Posts: 13,629
    Check out JoeQuick's "Universal Brain Squid" free on ShareCG:
    http://www.sharecg.com/v/73858/browse/21/DAZ-Studio/Universal-Brain-Squid
    Charlie
    Post edited by Charlie Judge on
  • MJ007MJ007 Posts: 1,718
    I need it for Commercial use.
    If anyone is willing to create a displacement/bump map to give it a brain pattern, please PM me a quote.
    -MJ
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,514
    someone with the full version of Filterforge easily could
    I only have standard that does diffuse jpegs of limited size :lol:
    you can use this one
    600 x 600 - 296K
  • Charles WestCharles West Posts: 123
    It has been a long time since I worked with emotiguy.... the sportspack and had worked on a brain pair but the old computer has died and I am now trying to set up a computer with the programs I need to start back again. The only way I could figure out a good looking brain was to use 2 emotiguys morphing one to the left side and one to the right side... I couldn't get the morph looking good enough.
    Good luck
    Caligreal
    768 x 614 - 69K
  • ArtiniArtini Posts: 10,903
    Just rendered in Daz Studio Emoti Guy with map off texture inserted into Diffuse Color
    and bump map inserted to Displacement Strength (strength set to 100%)
    from the textures rendered in Filter Forge Pro. I have set horizontal and vertical tiles to 2.
    Gamma 2.2 in Render Settings.
    1280 x 1024 - 165K
    Post edited by Artini on
    Below are the textures rendered in Filter Forge Pro, so you can use them as you wish.
    With Render Maps off.
    1024 x 1024 - 331K
    Bump map
    1024 x 1024 - 76K
    Diffuse map
    1024 x 1024 - 141K
    Normal map
    1024 x 1024 - 364K
    Ambient Occlusion map
    1024 x 1024 - 429K
    Reflective Occlusion map
    1024 x 1024 - 421K
    Does anybody knows where one can use Ambient Occlusion and Reflective Occlusion maps in Daz Studio material?
    I see that someone else worked on it... I still cant help it ... this is first attempt with just the bump map and some color changes.
    768 x 658 - 74K
    Using round ball from Sports Pack and diffuse and normal map tiled 7 times.
    1280 x 1024 - 156K
    Ambient Occlusion map as a Diffuse Color, also tiled 7 times.
    1280 x 1024 - 179K
    I am working on the morphs a bit with only studio and it is a learning process. I miss having the other editors... now if I can just find the backup copies to re-install the other programs. Here is another attempt.
    716 x 614 - 156K
    Thanks Artini and Caligreal!
    Caligreal, I really like how your version is coming out. Please keep me updated on your progress.
    -MJ
    -MJ
    hehe got hex working a bit more
    612 x 524 - 87K
    612 x 524 - 94K
    612 x 524 - 99K
