n00b showing how the forum users are helpful to us
ThunderCrew
Here are 3 renders. 2 of G6 and V6. "Bad" one of g6 / v6 is how I would get images sometimes "Better" one for g6 / v6 is how the forum reading helps work out uglies. :sick: :snake:
And 1 called "mirror" showing how I turned "planes" into "mirrors" via reading and tutorials posted.
Yes, I need way more work. It's a start though thanx to you.
I used 3 point lighting, shadow bias adjusting, converting 4th gen mat to fit gen2 models and a few more tips found on forums to help improve the "better" image for g6 / v6.
600 x 337 - 173K
1080 x 607 - 671K
1080 x 607 - 678K
I like the face makeup/jewelry, the style and pattern is something I would be proud to use in a scene. Tho that is yours for you to be proud of, I must walk my own path.
That last render is incredible, just the right amount of reflection on the floor, and just enough to tell the wall apart. the pose is also very good.
I agree, last render is very cool, image size could be a bit larger :)
Thanx, They are on my pc i do 1280 hd in 16:9 ratio but for forum posting figured shrink it some.
Thank you to both for comments.
