mcjSphericalUV - Spherical UV mapper - script for DS 1, 2, 3, 4.0 and 4.5+
mCasualmCasual Posts: 4,607
edited June 2014 in Freebies
https://sites.google.com/site/mcasualsdazscripts4/mcjsphericaluv
the idea is - you select objects in your scene and the script creates a copy of that object on disk
but, the UV map ( which governs the placement of texture-images on the surfaces ) is projected on the surfaces from either
- the position of the camera
or
- point ( 0, 0, 0 )
it could solve a problem like : you have an object which looks catastrophically not right when you attempt to apply a texture image to it - in fact some objects have no UV map at all and show up as 1 color when you apply an image
this script can also turn a standard Daz Studio primitive-plane into a ground plane that can blend in with a given environment sphere ( aka sky-dome ) - in figure 1 there's a 100 ft wide dome and a 100 ft wide ground plane, they have the same ( panoramic ) image applied to their surface - this was rendered in Blender, the Dome actually emits light and serves as the scene's lighting - the ground plane is matte and can receive shadows
1920 x 1080 - 295K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited June 2014
    in this example
    we start by loading an environment sphere - which is a gigantic sphere with a special panoramic photo applied to its surface
    we create and position a primitive-cylinder
    we select the cylinder
    we run the mcjSphericalUV script
    and 1 second later it's ready
    we load 2 copies of the cylinder
    and appply the same image as the environment sphere
    and tada we got palm trees!
    1920 x 1080 - 1M
    1920 x 1200 - 890K
    edited June 2014
    this time we are "in" a google streetview environment
    in Utah, possibly at the Daz inc building!
    we create a cube 15x15x15 divisions ( if it was 1x1x1 divisions we'd get distortion probably )
    and we project the UVs
    1150 x 656 - 131K
    1154 x 656 - 150K
    1148 x 660 - 212K
    edited June 2014
    a few notes
    the environment sphere is very large and centered at 0,0,0
    ( which corresponds to how the script sees the spherical image )
    i zeroed the specular strength and made the ambient color white 100% ( 50% for software renders )
    google streeviewt cameras are on a tripod on a car roof,about 8 ft above ground - around 240 cm
    so i placed the ground plane at y = -240
    the daz studio camera is at 0, 0, 0
    in blender, i made the sphere emissive and i made it NOT cast shadows
    i removed gloss from the ground plane (shadow catcher )
    at first the plane was visibly darker than the image on the sphere
    i added a Sun-light of strength 3, changed its size to .01 to make sharper shadows
    rotated it until the shadows were positionned like the rest of the scene and so that the ground plane blended with the rest
    1920 x 1080 - 228K
    1146 x 656 - 248K
  • Aave NainenAave Nainen Posts: 1,108
    This looks interesting......gotta keep track of this thread.
    edited June 2014
    in this case the spherical UV mapping was transfered to a 16x16m cube
    as long as the camera stays where it is we keep the illusion
    figure 2
    this is one of faces of the cube
    one could use this image to texture a plane
    and the big advantage is that the texture is not all warped and hard to modify
    Figure 3 this is the spherical map from streetview
    editing the brickwalls in Photoshop would be harder than
    editing the cube face images
    1280 x 595 - 444K
    1920 x 1080 - 515K
    1920 x 1080 - 834K
  • MilosGulanMilosGulan Posts: 1,993
    Very interesting, hope i will be able to use it :)
    edited June 2014
    just now i posted a version of the script
    for Daz Studio 1 and 2
    and one for Daz Studio 3 and 4
    ( in fact its the same exact code )
    the version for Daz Studio 4.5 and up will be posted soon, as in, say, 1 day
    the manual will also be improved ( i'll include the examples shown on this page )
    my videos featuring things spherically- UV mapped
    https://www.youtube.com/watch?v=ud_bwuNRXg0
    https://www.youtube.com/watch?v=NQs9ht31tuE
    1920 x 1200 - 269K
    edited June 2014
    the version for DS4.5+ is aaaaaaalmost ready ! i think
    got to test it with figures and figure parts
    in Figure 2 - i placed the camera in the center of A3's hips, selected the whole short pants figure
    and a few seconds later i had a copy of the pants with brand new easy to texture UV map
    in fig 3 the UV map for the same pants but zero-posed
    in fig 4 testing the ability to process only selected body parts, in this case Aiko3's hip and buttocks
    fig 5 re-UV mapping only the surfaces with the selected material named "SkinHead"
    note that this takes longer because the script reviews all of Aiko2's geometry looking for surfaces with that material
    732 x 716 - 261K
    1920 x 896 - 741K
    704 x 702 - 215K
    910 x 910 - 420K
    824 x 743 - 255K
    now available for Daz Studio 1, 2, 3, 4.0 and 4.5+
    933 x 299 - 192K
  • RAMWolffRAMWolff Posts: 10,382
    THANKS so so much Casual. This is one script I'm going to use very very soon! YAY!
    Wanted to ask. IF I were to use my Sphere Environ in a morphed state, like using one of the many land mass morphs I made for the ground plane would it help eliminate stretching or would it just read the default layout somehow and give me a flattened UV?
    Thanks sir! I'm guessing your a sir.... :red:
    1025 x 914 - 286K
    edited June 2014
    example of a Digital Elevation Map from NASA
    http://ava.jpl.nasa.gov/gdem.php?id=0201-32-
    fig 2 - this D.E.M. used on the displacement channel of a 1x1 plane ( Daz Studio Software render )
    fig 3 the D.E.M. converted into a morph of a 100 x 100 plane - using mcjElevate https://sites.google.com/site/mcasualsdazscripts/mcjelevate ( Daz Studio hardware render )
    fig 4 subdivided ( Daz Studio hardware render )
    1920 x 1080 - 1M
    1920 x 1080 - 2M
    1920 x 1080 - 725K
    2000 x 2000 - 789K
    the script projects the UVs on the positionned / scaled / rotated / morphed object
    so if you have a panoramic image which was taken from the point of view of someone at the bottom of a valley
    then ideally you’d project it on a ground plane shaped like that valley
    also it’s better to have geometry with many facets to reduce visibility of stretching
    the USGS has free DEM or Digital Elevation Maps ( well they had them 10 years ago )
    http://ned.usgs.gov/
    it’s gray scaled satellite images where the gray values are proportional to the altitude -
    using a 100x100 plane and my mcjElevate script https://www.youtube.com/watch?v=6dP8faP3KMo
    you could make terrains
    you could also obtain that result by applying the USGS DEM to the displacement ( or bump ) channel of the 1x1 plane surface
