anyone want this v3 face?
IkyotoIkyoto Posts: 1,159
http://www.sharecg.com/v/25079/gallery/11/Poser/V3-Face-Morph-Target
help? i have tried to make this into a V4 and Genesis 1 but it will morph pro in, but gives no dial- help please
  • Testing6790Testing6790 Posts: 1,091
    That face looks so familiar.
  • Richard HaseltineRichard Haseltine Posts: 111,390
    Is the problem transferring the shape to the mesh, or loading the mesh as a morph after transferring the shape? Do you have the Victoria 3 shape for Genesis (that won't let you load the existing morph, but it will make it easier to transfer the shape across)? Do you have GenX or GenX 2?
  • IkyotoIkyoto Posts: 1,159
    god GenX. morphloader pro says it created the morph, but no dial is to be found
    Try using Morph Loader Advanced, select the head of V3, and set the Load Morphs For option to Primary Selection (Vertex Only). This seems more reliable, without fiddling, for older single-body part morphs than Morph Loader Pro.
    I'll try that right after this render... maybe by Halloween.
    Texture is bought, but shape is mine.
