Desaturate a material/texture
3dOutlaw3dOutlaw Posts: 2,481
I want to take the output of a couple of the Visual Style shaders, and "desaturate" them, so that they render with less color. (for personal use of course)
Whats the best way to do that? I want to be able to save them, so I can use them on other characters. I cant find a setting in the Surface Editor to do it, so I was thinking added a brick in the Shader Mixer, right before the last brick, but which brick, and how to save that back as a new Shader is beyond me...?
Any thoughts?
  • Richard HaseltineRichard Haseltine Posts: 111,391
    edited April 2014
    Use a Binary Operation brick to take the dot product of the final colour with (0.3, 0.59, 0.11) and feed the result (which should be a plain number, despite the P (for point) on the output) into your root colour brick. If you want to partially desaturate, use a Mix brick to blend the dot product with the original colour.
    1795 x 962 - 120K
    Here's the Mix brick added, with Alpha controlling the strength of the effect
    1798 x 951 - 137K
    This is perfect Richard, so now after adding that...how do I store it, so I can use it as a material from my content lib?
    Apply it to a surface, then save a Shader Preset for that surface. You can also save the brick layout from the Shader Mixer File menu.
    OK, so I got a Shader Preset for a surface, but these shaders would apply to any surface. Do you know of a way to save them as a shader preset that would apply to the "selected surface"? I tried toying around with the Script itself, where it said Case "SkinTorso", and applied the settings, but the loop is calling that routine, and I tried a lot of things, and it either applied to that one surface, or to the whole figure. :(
    A Materials preset is for applying to certain named surfaces, a Shader preset is for applying to any selected surface on any selected item. Both will save brick layouts.
