Carrara 8 Pro Mouse config
patrick100patrick100 Posts: 0
Can I change the mouse commands? Zoom, rotate and pan? I dont like the standard configuration.
  • frank0314frank0314 Posts: 15,098
    It may be better to ask in the Carrara forum. I not versed enough in Carrara to know. I'll try and ask around
  • patrick100patrick100 Posts: 0
    Can I change the mouse commands? Zoom, rotate and pan? I dont like the standard configuration....
  • DUDUDUDU Posts: 1,945
    You can change your short cuts keyboard in your preferences.
    Moved to the Carrara forum
    Threads merged. All you had to do was ask us and we would've moved the thread for you. My bad I should've ask you if you wanted it moved
    I dont think that I can change the Mouse commands like , zoom, rotate and pan in the keyboard shortcuts preferences. Am I wrong?
  • dot_batdot_bat Posts: 373
    what kind of mouse are you using?
    You do not have 50 buttons on your mouse and it almost always goes in combination with a key of your keyboard and it is this one which you can change in your preferences.
    For the mouse itself, it is surely not possible, perhaps in Windows or Mac, I do not know, but there is no option in Carrara.
    Carrara:
    Zoom - scrool (ok) - middle button
    Pan - alt + holding right mouse button
    Rotate - alt + holding left mouse button
    I want:
    Pan - pressing and holding middle mouse button
    Rotate - alt + holding middle button
    In this way, I only use the middle button. Its a simple configuration, but I think Carrara doesnt allow this change.
