Lighting Help
JesterVIIJesterVII Posts: 175
Is there a way to turn an item in the scene into the light source? Like say if I wanted to make genesis' hands glow. How would I do that. I am only using DS4pro, no post work programs so my options are kinda limited I know.
  • Richard HaseltineRichard Haseltine Posts: 111,325
    uberArea shader will do that, it should be in the \Light Presets\omnifreaker\UberAreaLight folder. Select the object and the surfaces on the object that you want to cast light, then apply the shader. Adjusts ettings through the Surfaces pane, even though it's a light.
  • JesterVIIJesterVII Posts: 175
    Will give this a shot. thank you
  • JaderailJaderail Posts: 0
    edited July 2012
    Oh come on tell the truth. It's a light emitting Shader, that's why the settings are under surfaces. Just had to do that, sorry...Richard.
    Post edited by Jaderail on
