texture from camera
Hello!!! do you think there is a way to get a texture projection, as seen from camera?... I mean, like in cine4d, you can project the texture on the object exactly in the view- perspective of the camera... as soon as you move later the camera, it's not good, but if the camera stays in place, the trexture is very accurate...
You need the plugin SHADER OPS 2 at DCG
http://www.digitalcarversguild.com/plugin.php?ProductId=20
well, holywetcircuit, I own this plug, but know it very few... It seems to me that you can project a texture in the "view" of the camera, but I want to uv map from that view... in other words: uv map from the camera view, then export that map to photoshop, then paint, then re import in carrara... I think that with the plug in, I'm "blind", just projecting a picture on the geometry, like on a screen...
To export the map you will need BAKER from Inagoni.com
http://www.inagoni.com/e107_plugins/sgallery/gallery.php?view.4.1
I did not bother to line anything up, but I am able to export the Camera Mapping succesfully:
