All renders are pixelated
borgking001a
For two weeks now, I have been trying to create renders, and every time I hit render, I either get an error message or my renders come out pixelated. Is anyone else having this issue and what can I do to fix thix problem?
What do you mean by pixellated? Noisy, or low resolution?
Very low resolution.
Go to render settings, in general make sure the drop down for render target is new window. Then go up to pixel size, and type in a larger resolution. Or you can use a dimension preset, and choose a larger preset.
I've tried that before I made this post, and the same results.
Please post a screen shot of the Render Settings pane Editor tab, showing the General property group.
I don't know what happened, but they seem to be rendering out fine. I guess the problem is fixed, and I did nothing different.
So just a little update, it was doing it again, and some how the "Progressive Rednering" was turned ON, and I have never had it on. So problem is fixed!!!
