Question about Gen X
TheWheelManTheWheelMan Posts: 1,014
Are their some types of morphs thst you can't transfer via Gen X? I tried to transfer the Stan M4 character from RDNA to Genesis, but I when I try to dial it in after dialing in M4, nothing happens. I also noticed that the transfer wouldn't even work until I load the M4++ morphs, even though the product isn't supposed to need anything other than the base character. If I try to do the conversion without the M++ morphs! I gat an error saying that there are no morphs selected to convert.
If anyone has any suggestions, it'll be very much appreciated.
  • swordkensiaswordkensia Posts: 348
    I have encountered this with the 'Daniel' morph for D3.
    The Character morph just does not show up.
    I am hoping that the Soon to be released Gen X 2 might have an update to the conversion algorithm that may address some of these seemingly locked types of character morphs.
    Cheers,
    S.K.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,507
    and I can only do Phoenix Lola's head not body
    oddly enough
    and she does not need morphs++ injected
  • TheWheelManTheWheelMan Posts: 1,014
    There must be something different about how the morphs or the injection poses are set up.
    edited February 2014
    In Poser, Stan's head loads at zero under Body, but full strength under Head. Since GenX is loading the head inj into the Body group, it's not automatically applying the strength.
    To transfer through GenX, after loading M4 and Stan's +Head_INJ, expand the BODY group in GenX and manually place the checkmark in the far left column for the Head2 morph, and change the 0 in the Value column to 1. Set your options as normal and transfer.
    Do the same for the lean/plump torso injections if you're transferring those as well.
    Post edited by Lissa_xyz on
    Thank you so much, Vaskania! I'll report back with my results as soon as I have time to try it.
    Worked like a charm, Vaskania!
    1600 x 1000 - 281K
    Glad it worked. Nice image too!
  • kyoto kidkyoto kid Posts: 42,084
    ...nice result.
    Thank you, guys! Once I got bit working, I just put this together so I could show the results.
