Simple Plastic Shader
Takeo.Kensei
Hello,
A little shader that could give some speed improvements over existing shaders in DS. Nothing spectacular though from my tests but if you have lots of transmapped objects in the scene that could make some difference in the end
Nothing complicated and nothing fancy, just a plastic shader, so there is no visual improvement to await from it
Only for DS 4.5+. I only tested it on DS 4.6 latest version so not sure it will work on all versions.
Get it here
[Edit] Seems I screwed up something the first time so better download the updated files
Post edited by Takeo.Kensei on
Thank you!! Will test ASAP
