tip for cleaner Bump / Displacement effects
mCasualmCasual Posts: 4,607
edited July 2012 in Daz Studio Discussion
most images in the netverse use 8 bits per color channel, which gives us 256 grayscale levels.
image 2 : yuppp8.png was applied to the Displacement channel in daz studio and software-rendered.
By converting this graymap to a 16-bit tiff file and blurring it a little
we can get rid of the staircases.
it's not as good a solution as having a natively 16-bit map but i think it helps
the freeware way is : imagemagick from www.imagemagick.org
write a batch file like this ( use notepad and save it as go16.bat )
c:\imagemagick\convert yuppp8.png -depth 16 -blur 16x16 yuppp16blurred.tif
note that this batch file pre-supposes that imagemagick was installed in c:\imagemagick
note: it also pre-supposes that yuppp8.png is in the same folder as go16.bat
the 16-bit tiff image will be created in the same folder as go16.bat
you run the batch file, by double-left-clicking on go16.bat
it will convert 8-bit png image yuppp8.png into a 16 bit softened image named yuppp16blurred.tif
image 3 : yuppp16blurred.tif was applied to the Displacement channel in daz studio and software-rendered.
600 x 600 - 169K
600 x 600 - 216K
600 x 600 - 11K
600 x 600 - 16K
512 x 512 - 8K
Post edited by mCasual on
  • PendraiaPendraia Posts: 3,631
    Thanks for this info!
  • Lamb FriesLamb Fries Posts: 0
    Yes, thanks! I have not had a chance to implement it but displacements are a great solution to keeping poly count down in models so getting cleaner results make quite a difference.
  • pwiecekpwiecek Posts: 1,598
    You can do this in Photoshop (or equivalent) program also.
