Rons Brushes - how to make them look "good"?
XoechZXoechZ Posts: 1,102
Hello!
Recently I bought some of Rons Brushes. They are very cool for postwork. Especially these two are really great:
http://www.daz3d.com/rons-rain
http://www.daz3d.com/rons-hydro-explosion
because I love water effects :-)
But I have a problem with the useage. When I use these brushes in postwork (Photoshop Elements 11), they look good, but not good enough. They look something like water, yes, but far away from the quality in the promo images.
So, what is the secret to make them look good and real? Any special filters, layer modes or adjustments?
Any help is very welcome! Thanks.
  • LycanthropeXLycanthropeX Posts: 2,287
    how good you want them to look?
    1920 x 1080 - 297K
  • XoechZXoechZ Posts: 1,102
    As good as possible :-)
    I want them to look like real water. Like in the promo images. Like water that really belongs to the scene and not just a brush that was inserted and "looks like water". Hope you know what I mean.
    i used Ron's splashes for the scene above
    Nice. So, what did you do with them after inserting the splashes on the render? This is my basic question.
    wellllllllllll that scene was a serious cheat.
    i created a separate layer above the image, then painted ron's splashes in white on that layer, but i saved the layer as its own image in PNG format
    Then I imported both my original image, and the splash layer into Hit Film and used the splashes to control a displacement effect.
    so that one was a big time cheat
    edited November 2013
    in effect, rather than seeing the brush, you are seeing the displacement effect in the shape of the brush
    i have another image that uses a ton of ron's brushes, but unfortunately i used them for about 3000 gallons of blood, so i don't think I can post that image here because of the TOS
    Post edited by LycanthropeX on
    I understand. Can something similar be done inside Photoshop?
    I know I can do something similar in Paint Shop Pro, generally if PSP can do it then Photoshop can do it for sure
    Thats cool, I also own PSP X6. I love the filters in PSP :-) So, how do you do it in PSP?
  • Coon RaCoon Ra Posts: 200
    The brushes have no depth. Add the depth manually by dodging and burning splashes used on separate layers. Do not mind to use some different tones of a tint to add more feel of depth. Partial embossing of splash details may add a bit to realism as these details would get the sense of volume through the subtile light/shadow gradient effect.
    ok Displacement maps in PSP are pretty easy, Open your image, create a new layer, paint your brushes in white, create a new layer between your brush effect and your image and fill it with black, save the white brush and black layer as a merged layer to Corel_04 folder in your PSP folder. Ok at this point you can make the black layer invisible, or delete it cause you are done with it. Keep the white brush layer but make it invisible for now, select your main image layer, click effects, distortion, and then displacement map. load the image you saved to Corel_04, make sure you are set to 3D map, adjust your blur and intensity, for this image i had blur set at 12 and intensity set at 3. click ok
    then i made the white brush layer visible again, set it to hardlight and adjusted the opacity.
    the displacement wraps the image around the shape of the brush a little to give it that watery distortion effect, this image isn't the best example, i threw it together quick just to explain how to do this.
    1920 x 1080 - 468K
    Ok, I will try that.
    Thank you very much!
    Post edited by XoechZ on
  • TaozTaoz Posts: 10,307
    Sveva has a Stamp Brush Tutorial at Rendo...
    Greetings,
    Have you actually gotten it? If so, how is it?
    It's in my wishlist, but I never get around to prioritizing it...
    -- Morgan
    Cypherfox said:
    Greetings,
    I have it but haven't used it yet - bought CS6 a while ago but decided to wait with installing it until I've upgraded to Win 7.
    It looks great though with lots of illustrations, can't imagine you could want more from a tutorial. It gets lots of good reviews too.
    what would be kool is if we got ron to make a tutorial on how he uses his brushes
  • ISIKOLISIKOL Posts: 386
    A good way to use ron brushes is with gradient maps above them...if i had to bet i think this is the way Ron is doing it..what is the procedure...
    Take for example a generic cloud brush
    In photoshop:
    Make a screen layer above your image filled with completely black
    Make a gradient map above the screen layer...use a gradient from complete black to red orange and then yellow
    Clip the gradient map with the screen layer
    Paint with white in the black screen layer...with the cloud brush
    See the result :) it looks better with dark backgrounds...
    P.s. You can check my gallery to see some examples..i use them all the time..i have a gallery here also..
    Post edited by ISIKOL on
    I also use the brushes in combination with other programs and filters. I already showed one where i used the brush image and combined it with a displacement effect in HitFilm. I have also used them with plugins like Filter Forge or Eyecandy, Xenofex etc. Also I tend to use brushes for things other than what they were intended for. I often use wave brushes for mud splatter on vehicles, or blood spray, etc. Get creative in your thinking and you can do a lot with brushes.
  • luci45luci45 Posts: 2,933
    Ron's Flames has a tutorial with it. i just tried it out and it works great and can be applied to other brushes. basically he uses transparent layers of the same brush in different colors with above layers set to "color burn." The flame used yellow and orange (and optionally red.) Overlay and Soft Light work pretty well too.
    His promo shots for Ron's Angel Dust look like he used a gradient map on a layer as Isikol mentioned. I am going to try that next. Thanks, Isikol for the nice tutorial on Deviant Art for the war image, which is pretty spectacular.
    696 x 1200 - 180K
