C85: import eps/Illustrator
DonleavyDonleavy Posts: 34
Hi
Is it possible to import an EPS/Illustrator file in Carrara 8.5 - in order to do a simple extrusion? I can't figure out how to import a vector file...
Br, Dl
  • rk66rk66 Posts: 450
    Hi,
    in the Spline Modeler > File > Import.
    rk.
    Also, from what I gather, an older illustrator format will work better than a newer one.
  • JamyJamy Posts: 192
    hi,
    it's work perfect if you export your file in Illustrator 8
  • DonleavyDonleavy Posts: 34
    I still can't import. I can go to the model mode by clicking on the wrench, but how do I go specifically to the spline model mode? If I go to the model mode with an object selected I can edit the object, but I still can't import any Illustrator/EPS files.
    Ah! I insert a spline object. Then I am in the spline modeler.
    Thanks!
    I was going to post some screen shots, but I see that you figured it out. Good luck!
