Inject PMD
assmonkeyassmonkey Posts: 0
I download this plug-in to use Die Trying's V4 morphs
Issue is...ave no idea how the plug-in even works
I downloaded it, I installed it into the plug-in folder...and, have no idea what to do after that
    edited September 2013
    Depends what version of DS you're using. AFAIK InjectPMD was never updated to work with versions beyond DS4.
    /edit
    There is a java app called Morph Exchange you could try.
    http://www.kuroyumes-developmentzone.com/poser/freebies/
    I've never used it, nor have I had to, so I can't help you with it.
    Post edited by Lissa_xyz on
  • assmonkeyassmonkey Posts: 0
    Does Daz 4.5+ load PMD without help?
    If so...that's not working on my end
    No it does not. Daz does not recognize PMD's except when loaded by a CR2. Bejaymac posted a tutorial of how to convert PMD morphs for Dawn into usable files for Daz. You could read through it and see if you can adapt it for use with V4.
    http://hivewire3d.com/forum/showthread.php?511-PMD-to-DS
    Quite honestly, I think the easiest way to do this is with Poser (Poser 9 is $30 until Sept 30). I haven't tried this myself, so I'm not sure it would work, but if you have/get access to Poser, you could disable external binary morphs in the options and then load each morph and resave it to your library as a new pz2 file. This may put what was in the PMD directly into the new PZ2.
    *sigh* no poser, nor do I have the want to spend money on the program
    Unless someone has transferred the Die Trying morphs without it being a big fuss...then I'm not sure what to do
    And I have no idea how to even use the Morph Exchange tool, the thing seems over complex for what it's doing. And the tutorial...is missing some things. Like...what the hell are they even editing (when they out said we're not going to edit the CR2 or make a copy...then what the hell are they using)
    Does anyone have a non-PMD version of this morph pack?
    The first part of Bejaymac's tutorial is creating a "dummy cr2". It says right in the tutorial. There is coding involved.
    If all else fails, you could try to get a hold of Die Trying and see if they're willing to do a PMD free version for V4 that works in Daz.
    Yes, I saw the dummy.cr2...doesn't help me one bit
    Saying what they're using and not showing how they made it...sort of doesn't help. I don't know what a dummy.cr2 is, nor do I know how to make such a thing
    A CR2 is a renamed text file. You could to it in notepad if you really wanted to.
    Well, can't even do it, because you need to know the morph names
    thanks anyway
    Open the pz2 in a text editor, they're all listed.
  • Richard HaseltineRichard Haseltine Posts: 111,202
    Merged threads.
