editing Gen4 hair (fixing something)????
assmonkeyassmonkey Posts: 0
edited December 1969 in Hexagon Discussion
Ok, I'm trying to see if I can move Gen4 over to fit Genesis.
I tried a simple hair...that had like...no morphs. I was able to save it after it converted in the auto-fit
My problem now is...like, when you morph the ears, the hair moves with it...like in an awful way. The ears just don't poke through, the whole mass moves and forms around the ears.
What can I do to fix this?
  • fixmypcmikefixmypcmike Posts: 19,565
    Select the hair, go to the Parameters tab, and in the options menu make sure "Show Hidden Morphs" is checked. There will be a morph in the hair for every Genesis morph that is set to auto-follow. Find the morph for the ears and dial it down.
  • assmonkeyassmonkey Posts: 0
    Well, the "Show hidden Proprieties" is checked
    I"m not sure what I need to dial down.
    Am I dailing down something under the "Mesh Smoother"
    No, you should see a morph dial with a name similar to the ear morph on Genesis
    Oooohhh, I see it
    When I morph Gen's ears, a new morph a new morph is made by the hair
    thanks for the help
