Daz mode, or glitch?
AngelAngel Posts: 1,204
edited May 2013 in New Users
I cant get rid of this thing. I don't know what I did, or how to disable it. If this is a mode then I just need to know how to disable it.
If this is a glitch or something I need to know how to fix this. Thanks
https://www.youtube.com/watch?v=_rNkDZa55x0
Post edited by Angel on
    You need to go to Window > Tabs > Tool Settings, and change During Manipulation - DrawStyle to Use Current (Off).
    You can also just post images on the forum here by using the Browse button just above where you write your post.
  • fixmypcmikefixmypcmike Posts: 19,711
    Window > Panes > Tool Settings
    Under "During Manipulation" set Draw Style to "Use Current (Off)"
    I do not know it is same as your case.
    but as for me,, when I load saved scene, in new beta daz studio,
    and zero poze, or pozing figure,, about some scene,,
    the mesh often break in 3d view only,as like your pic.
    then I checked many times,, and find,,
    I need to set SubDivision Delayed (off) to Persist (on),
    before tweaking figure.after load these scene. (pic 1)
    if I do not change the option,, and move rig,, or zero pose
    about which I saved before in current product version, often break, and I can not correct it.
    (pic 2)
    but if I change setting to Persistent (on) , after load the scene,,
    I can move rig or zero poze,
    then return setting to Delayed (off), there is no problem.
    it is so wired,, because,, I can not say,,it happen every times with the option..
    but I can re-make the break sceane.
    https://bugs.daz3d.com/view.php?id=50341
    977 x 614 - 107K
    edited May 2013
    I find answer ^^;
    as for me,,, I need to change Display optimization,, best to better ,,
    if I change better,, the broken 3d view re-made,,, .and how I set the subD,or skinbinding,
    the problem do not happen about the same scene.
    it seems my,,AMD graphic card problem?!
    why,,,why I can not use,," best" ,,,
    I am so shock ,,I want to cry,,,.
    then now I find,, I miss the place to reply,, these problem is not concern about this topic,
    so sorry ><; I opend many pages at same time,, so I missed .</p>
    Post edited by kitakoredaz on
  • AngelAngel Posts: 1,204
    Thanks for the help guys. your great.
