Carrara v8.5.0.149 (PC/Mac) Beta Update
DAZ_bfurnerDAZ_bfurner Posts: 62
edited July 2012 in Carrara Discussion
CARRARA 8.5.0.149 is the latest Beta Build!
We are making this build available for $0.00 as a store item CARRARA 8.5.0.149 Beta You can run the production build of Carrara 8.1 side by side with this Beta build. Just don't uninstall 8.1 version when you install this beta release.
The purpose of providing this build is for you to see the progress we are making, see how Genesis looks in Carrara, see the new features we've added and provide input on the changes. You can also see the list of bug fixes below. This list identifies issues that were logged in the bug tracker and highlights many of the other fixes in this build.
New in Carrara 8.5:
1. Support for imported Genesis .dsf files (best used with DAZ Studio 4.0.3.19 or newer installed).
2. Character presets can be applied. Go to the Instance Tab, select the 2nd Genesis listed in the tree or the Actor line, and double click the character from the list. If the one of these items is not selected, an additional figure will be loaded with that character applied.
3. New Parameters Pane and user experience
4. Carrara 8.5 Parameter Pane. If you are familiar with the Parameters Tab (with the Genesis figure) in DAZ Studio 4, the equivalent to Carrara 8.5 is the Parameter Pane which is accessed by selecting the second Genesis from the list.
5. Shaping in Parameters Pane. If you are familiar with the Shaping Tab in DAZ Studio 4, the equivalent for Carrara 8.5 can be accessed by selecting the Actor line from the tree in the Instance Pane.
6. Content Management System or CMS connection to utilize the DAZ Studio database (requires DAZ Studio 4.0.3.19 or newer recommended to be installed). We are looking into a project to install the CMS for Carrara without the need of DAZ Studio. So for the Carrara customers not using DAZ Studio they can still take advantage of the new system. More information will be coming.
7. AutoFit is included in Carrara 8.5
8. Fit To (auto generates Genesis morphs) for Genesis designed clothing
9. Restore Figure tools
10. Memorize tools
11. Zero Figure tools
12. Smart Content Tab (shows all the content with meta data organized similarly to DAZ Studio's Smart Content Tab)
13. New SubD / Smoothing tool (display the smoothing slider of smoothed vertex object in the assemble room)
14. Improved Bullet Physics for soft body simulation
15. aniBlock importer has been updated and fixed for Carrara 8.5
16. Mac OSX Lion support has been implemented
17. Geo grafting has been implemented and we continue to work on this feature
18. New Light Icons to better represent the lights, the controls have also been improved.
19. DUF Files from DAZ Studio are now supported in Carrara 8.5 however, DUF material presets do not always apply textures to the selected figure.
If you are seeing issues please log the bugs in the bug tracker: DAZ BUG Tracker
Changes since the last beta build include:
Rendering : Fixed #0045322 : Fixed too blurry texture when using Gaussian filtering
Rendering : Implemented : Optimized Gaussian filtering speed
Rendering : Fixed #0045322 : Fixed too blurry texture when using Fast Mip-Map filtering
Rendering : Implemented : Optimized Fast Mip-Map filtering speed
Carrara : Fixed #0046807 : Fixed camera "Set Position To" undo issue
Carrara : Fixed #0046163 : Fixed splat primitive bounding box size
Carrara : Fixed #0046803 : Fixed camera popup list update issue when renaming a camera
Carrara : Fixed #0046824 : Fixed deadlock with projection shader and displacement
Carrara : Fixed #0046825 : Fixed crash when opening the scene attached to this bug report
Carrara : Implemented : Updated French translation
Mac : Implemented : Implemented sleep function
DSF : Fixed #0046510 : Fixed grafting rigidity crash
DSF : Fixed #0043643 : Fixed morphs issue on some content
DSF : Fixed : Fixed crash with conforming when the object does not have any geometry
DSF : Fixed #0044491 : Fixed issue with bulge
DSF : Fixed #0046451 : Fixed corruption issue with autofit and conforming
What you need to know about this build:
1. If you get a Duplicate ID error, please reset your download for the content and try reinstalling. If the issue persists please place it in the Content Project of the bugtracker (http://bugs.daz3d.com) as we believe we have fixed all of those.
2. Pz2 material Presets do work on Genesis and Triax Content, to include content that has been auto-fit to Genesis now.
3. PZ2 Poses do apply to Genesis but it is not recommended and if the pose has translations on the feet or hands those will need to be zeroed.
4. DAZ Studio4.0.3.47 minimum, (4.5 RC2 recommended) must be installed prior to running Carrara 8.5 in order to use Genesis or the Smart Content Tab.
5. If new content with meta data is installed, DAZ Studio will need to be started in order to get the smart content into the CMS database.
6. V4/M4/K4 shaders will not work on Genesis and will have to be manually built.
7. Our development team is working on the tools to transfer data from DAZ Studio 4 to Carrara using our new file format.
8. Included Tree presets may not look the same as they did in Carrara 7, we are looking into this currently.
9. Adding IK to genesis works correctly and as expected, Genesis doesn't load with IK. (In either DS or Carrara)
10. Mimic fixes have been implemented for Gen 4 and earlier.
11. Mimic and Mimic Pro for Genesis is fixed and will be made available to those who have purchases this.
12. Plugins for the previous builds of 8.0 are expected to work with this version.
13. The CMS service is not embedded in this installer. You will need to have installed DS 4.0.3+ “with Content” to be able to use that functionality.
How do I get this updated Beta Build of Carrara 8.5?
Carrara 8.5.0.149 Beta
To register the Carrara 8.5 Beta you will need to use the serial code listed here: CDZCPRO-085-0000026-BLW-001-EBTOLPQ (Expires August 31st 2012)
About Mimic Pro and this build:
If you own Mimic Pro and want to start using it with Genesis, you'll need to download a build just for Carrara 8.5.0.149. You will NOT want to use this with your 8.1 build of Carrara. It won't work with both builds. However, if you install the new version in a different location, you can continue to have both versions on your machine. The same serial number will continue to work for both builds. The DMC files are also included in this new version of Mimic Pro and will work with Genesis.
To see many of the new features and read the latest news on Carrara 8.5 visit CarraraCafe
Post edited by DAZ_bfurner on
«1345678
  • HeadwaxHeadwax Posts: 10,458
    thanks for the update !
  • JoeMamma2000JoeMamma2000 Posts: 2,615
    Really, you guys cannot be serious. Unless my memory is WAY off, I recall that the first 8.5 beta was made public over a year ago. Sometime in March a year ago. Actually, that makes it one and a quarter years ago.
    Now maybe you guys have developed a new idea for the purpose of betas, but in my world it is NOT to ask your customers to work on checking your bugs for a year and a quarter. It's to make a fairly quick check at the end of development to make sure the software works on multiple platforms and configurations.
    And based on the list of big stuff still needs fixing, I'm guessing it has still got a long way to go.
    Add to that the fact that Genesis is mostly for DAZ, not the users, in spite of what you want to tell everyone. For those who have no interest in spending more money on new Genesis content, there isn't squat in 8.5, except maybe the new Zero/Memorize/Restore tools which should have been implemented 10 years ago.
    I've been as objective and supportive of DAZ as I can be, but seriously, if you want to stay in the software game (which I sincerely doubt) you are really gonna need to step up your game a lot. At this rate, it's gonna be at least another two years before you get a decent, and very basic cloth sim, which other software has been doing for decades.
  • hzrhzr Posts: 210
    How and where? Would be great to get an explanation about this implementation and functionality. Also, does this work on genesis only or also on other figures?
    Hi Joe, welcome back!
    Does this mean you are not happy with this update?
    (just a small joke) ;)
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    Last March was when the last release build. 8.1.1.12.While the 8.5 development cycle has gone on much longer than we would have liked, it hasn't been quite that long. :)
    edited June 2012
    How and where? Would be great to get an explanation about this implementation and functionality. Also, does this work on genesis only or also on other figures?It works just like it does in DAZ Studio. And, no it is not limited to Genesis. I have seen Faba do some work with Geografting on an original figure. (Though I believe it was rigged in DAZ Studio.)
    Edited for clarity:
    Geografted parts are applied just like Conforming clothing. With the base figure selected (The one the graft is applied to) double click, or drag and drop from the browser to the figure (either in the assembly room window or the Instance list) and it will apply for you.
    Simple to use, lots of cool possibilities.
    Post edited by DAZ_Spooky on
  • DAZ_bfurnerDAZ_bfurner Posts: 62
    There is also a brief overview of Creating Geo-Grafting in DAZ Studio, this tutorial is not finished but will give some overview of how to do it. See it here: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/assembling/tutorials/geo_grafting/start
    A little more info on the geo grafting:
    Nothing special should be required to use the geo grafting. If an item has geo grafting, it will be grafted to the base when the item is conformed (fit to). It will he ungrafted when in un-conformed.
  • BrianP21361BrianP21361 Posts: 816
    I just installed the new beta and I'm not seeing much of a change. The post says:
    But material presets for the Supersuit (for example) don't show up in the browser. Are they DUF presets. Is that why they don't display. It also says that PZ2 poses do apply, but I can't figure out how to apply them. I've selected the Genesis figure and then tried to import the PZ2 file, but they are greyed out in the dialog box. What am I missing?
  • thoromyrthoromyr Posts: 452
    Just thought I'd let you know we haven't hit the anniversary yet. My oldest download is 26 September, so it was probably available early/mid September when it was first released.
    Call me crazy, but I'm glad they're fixing bugs, and 8.5 works better for me than the last 8.1 so I'm happy to use the beta software.
    Cheers!
  • KGKG Posts: 0
    Hi
    I m trying to download the Carrara 8.5 but I cant
    If I click the link it takes me to the store but when I click add to cart nothing happens, the screen flashes and thats it
    nothing in the cart
    If I go to my account, to itemized order history, try to reset my Carrara 8 Pro purchase and nothing happens, I go to the
    downloadable products and is not there neither the 8 Pro version link nor the Beta
    What am I doing wrong?
    Thanks
  • 3DAGE3DAGE Posts: 3,315
    HI JorgeMR :)
    I just tried clicking the link for the Beta, and added it to my cart, and processed that , and it's in my available downloads Now.
    It could have been just a Glitch in the store,. ..Try it again.
    Hope it works for you :)
  • bytescapesbytescapes Posts: 1,910
    edited June 2012
    Yes, it's a slow development cycle, but I'd rather DAZ took their time and got it right than shipped something half-baked.
    And if that means getting customer feedback at every point in the cycle, I'm cool with that too.
    I even think that 'beta' may be the appropriate term for it. In my understanding of software development cycles, the terms 'alpha' and 'beta' refer not to level of code completeness, but to distribution: 'alpha' is "internal or partner testing only", and 'beta' is "shipped for testing to a limited range of test sites". Then Netscape shook that whole idea up by introducing the idea of a 'public beta', which I guess is what this is.
    I'm eager to see a final version of C8.5 but I'm not going to quibble over the naming of the interim builds. The alternative - shipping beta-quality software and calling it 'final' - seems worse in my eyes.
    Post edited by bytescapes on
    The Supersuit uses DSA (DAZ Studio Script) presets. Unfortunately only DAZ Studio can read DSA files.
    The presets for the Supersuit, in particular, are mostly shaders, which will not work in other render engines, so even if Carrara could read them, they probably wouldn't work.
    On the other side of the coin, making Carrara Shaders or using Carrara shaders on the Supersuit can give you some really amazing results. This is especially true of you have Shoestring Shaders, and/or Veloute (included in Advance Pack in the DAZ Store)
    For applying a pz2, in Carrara, the easiest way is to, with the item you want to apply the pz2 to selected, and double click the pz2 in the browser.
    Spooky,
    Thanks for the response. I understand that shaders are different in Studio from Carrara, but it would be really nice if texture maps, bump maps, normal maps, etc were able to load. I recreated the Mr. Hyde textures in Carrara and it took hours to load all the maps. Plus I had to adjust all the channels to get everything to look right. Many of the presets for Supersuit also contain morphs and consolidation of the shading domains (at least it looks that way to me), the seams are grouped into the main body parts sometimes. At least getting those parts into Carrara would save a lot of time.
    The PZ2 files that I want to apply are not in runtimes so they don't show up in the browser. They were free on ShareCG. I guess I have to put them in a runtime. create. With M4 and V4 I can apply a PZ2 file by selecting the figure and clicking on Import > Prest (Pose, Material). The import option doesn't show up for Genesis.
    239 x 462 - 37K
    Spooky,
    Trust me, I feel your pain. :)
    The Morphs, maps etc. will come across, though there is a change to how DS is saving things in a build of DAZ Studio after the current public Beta. This should make the maps come across better from a DUF (custom shaders still can not come across). It is not going to happen from a DSA and as long as custom shaders are not used, it should also work with a PZ2.
    With the next public Beta of 4.5 you should be able to resave those dsa as duf and bring them into Carrara and lose at least half of the work.
    I do highly recommend the use of Reference Shaders to make the shaders you need to be the same, the same so changing one changes them all, without losing the flexibility of the Supersuit.
    Spooky,
    Thanks Spooky. I hope you're right about the next beta. Although this does ad an extra step. I don't typically use Studio. I only loaded it for Genesis. Better an extra step than no result at all.
  • DartanbeckDartanbeck Posts: 21,988
    Hmnpf!
    Come back to check out the new forums only to find a shiny new C85beta! Thanks Devs! I'm still loving the last one!
    I took on some heavy manual labor jobs to bide my time for Daz to iron out their new store so I wouldn't drive everyone nuts with how I felt about the initial launch. It worked. Now I look and like what I see. Bravo!
  • djmulcahydjmulcahy Posts: 42
    edited June 2012
    Hmmm... this is the first time I've loaded up 8.5 in many months, so I don't know if this is an ongoing issue or if it's just something I'm doing wrong...
    But I'm trying to save an obj by dragging and dropping it from the Instance Menu to the Objects tab in the browser, and I keep getting an I/O error.
    My fault or Carrara's?
    Edit: And I've tried different obj's, as well, all with the same result.
    Post edited by djmulcahy on
    HI djmulcahy :)
    It's working fine for me here.
    single objects or groups and animated groups, working as expected..
    Anything unusual about your Objects folders. ?
    Anything you drag'n'drop from the instance list into the Browser (objects) tab Folders, should be getting saved as a .Car file.
    Can the objects be exported as a .Car file on it's own. ?
  • 3DLust3DLust Posts: 230
    edited June 2012
    I can't open any .duf files - reported it in the bug tracker.
    468 x 60 - 17K
    468 x 216 - 20K
    Post edited by 3DLust on
  • WoolyloachWoolyloach Posts: 0
    Ok, I'm getting unexpected behavior out of this BETA:
    - Load K4
    - Load Bramble Berry Fairy Hair
    Carrara loads the hair, then I get this message "Projecting Morphs" and in the 10 minutes I've sat here, it's only at 16%!!!!
    Is this "working as designed"? I've never seen tis message before and it seems a bit extreme to take this long to load a simple hair. I know my wheezy dual-core T4400 at 2.3GHz isn't a screamer, but DS4.5 and PPro 2010 both load this in seconds.
    Is this bug-report-worthy material?
    Also, some UI feedback during morph INJ/REM would be nice as I spent several minutes clicking an INJ without any feedback or indication Carrara had heard me.
    ... Carrara loads the hair, then I get this message "Projecting Morphs" and in the 10 minutes I've sat here, it's only at 16%!!!! ... Is this bug-report-worthy material?
    Report it. It may not be a show-stopper, but it's certainly an irritation, so it's something the developers should know about. (Of course, if 'Projecting Morphs' never finishes then it is a show-stopper, so they should definitely hear about it).
    Make sure that you write it up in detail so that they can reproduce the problem. I've always been taught to write bug reports in four parts as:
    1. Steps to Reproduce
    2. Expected Behavior
    3. Actual Behavior
    4. Additional Information
    ... some UI feedback during morph INJ/REM would be nice as I spent several minutes clicking an INJ without any feedback or indication Carrara had heard me.
    Carrara's not great on giving feedback. There are a bunch of operations - applying a MAT pose, for example - where it stops responding for an indefinite amount of time, with nothing to indicate that anything's happening. It's an aspect of Carrara that the developers could usefully do some work on.
    3. Actual Behavior
    It did finish after about 18 minutes of waiting, urgh. I'm off to report it after this post!
    Glad to see it's not just me that thinks some UI feedback would be nice! Even a silly spinning cursor would work.
    3DAGE said:
    HI djmulcahy :)
    Thanks...
    I could save objects modeled in Carrara without trouble, but importing anything prevented me from saving it.
    After uninstalling Carrara and reinstalling, it's working normally again. Those same imported objects are now saved without a hassle.
    Something funky was going on there.
  • Scott LivingstonScott Livingston Posts: 4,348
    edited June 2012
    I've never used (or bought) Carrara before, but I'm impressed with what I've seen of it. Two questions:
    1. Does this beta require that you have a previous (purchased) version of Carrara installed?
    2. Is it intended only for those who have previously purchased Carrara?
    Post edited by Scott Livingston on
    Hi Scott-Livingston :)
    1./ The beta should be installed into a New and Separate folder from any other version of Carrara,.(if you have one installed) but it's not dependent on having Carrara installed previously.
    If you want to,. you can also download the 30 day Trial version of Carrara 8 from www.downloads.com. and compare the old with the new.
    2./ Yes, the Beta is being provided for "testing" purposes,. so ideally having some experience of the way Carrara works would be helpful in spotting any issues in the current beta version,. However.. new features, are new features to everyone, so all input is welcomed,
    Hope it helps :)
    I can't find a link to the bug tracker now - can someone please post it? Thanks in advance!
    3. Actual Behavior
    Hi Woolyloach :)
    There's a Link to the bug tracker in the text on Page One.
    Bug Tracker
  • 0oseven0oseven Posts: 626
    QUOTE or Veloute (included in Advance Pack in the DAZ Store
    Veloute much cheaper direct from Inagoni who reduced their prices 50%
    http://www.inagoni.com/news.php
