save D-Former results as morph in DS 4.5?
I have made some progress on character modification but can not find a way to save the adjustments made with the D-Form tool as morph targets. I have searched here and Youtube but all tutorials are based on using external programs or older versions of DS.
How do you save a morph created with deformers in DS4.5 for use in DS4.5?
OS Win7
DS4.5 64 bit
  • Richard HaseltineRichard Haseltine Posts: 111,329
    Which figure? Is the problem creating a morph target (use the Spawn Morph button in the DForm pane - Window>Panes(Tabs)>DForm) or saving your work (File>Save as>Support Asset>Morph Asset for Genesis, if you want the morph generally available, save as a scene subset otherwise)
  • edited December 1969
    Working with Genesis Basic shape, Was having problems with both steps since I was not sure which tabs or order of events to use. Thanks for the assistance, I now have a new morph and the knowledge of how to create more.
    Necro post, but why have yet another thread about this  :)  Adding a morph to the one piece swimsuit.  Spawned it, it works, now save as support asset, morph asset.  Works.  Then reload a new copy of the boathing suit and it is not there?  What am I missing?
    1597 x 730 - 170K
    What is telling the new copy of the bathing suit to load the morph from your morph folder?
    Where are the PA made morphs for the bathing suit located?
    edited July 2021
    Interesting, I was thinking it was very basic with no morphs...but in the vendor folder there are a lot! (thank goodness)
    ..\content\data\Nikisatez\ONBSG3\One Piece Bathing Suit\Morphs\Nikisatez
    Mine new one got put here:
    ..\content\data\Nikisatez\ONBSG3\One Piece Bathing Suit\Morphs\3doutlaw
    ...and none of them are showing up?
    The mystery deepens...I need to check my directory manager
    OK, I closed it all down, restarted and my morph shows up.  It's like rebooting a PC.  I should always try that before posting.  Thanks
    Post edited by 3dOutlaw on
  • LeanaLeana Posts: 13,499
    at a guess, the "content" folder in the path shouldn't be there.
