Help! all my Genesis characters have Stephanie 5 Curvy dialed in
WendyLuvsCatzWendyLuvsCatz Posts: 41,489
edited April 2013 in Daz Studio Discussion
I have no idea what I did
have been using Dimension 3D's DSON importer in Poser
I resaved Stephanie 5 curvy as a .duf to use in Poser with the presets I wanted
not as Genesis
as Bigboobed Stephy as to not overwrite anything
but now ALL my figures have her dialed in when they load in studio (and Carrara)
I fixed the default grey startup figure by zeroing it and resaving but all my presets are ruined
I can manually just dial her out each time for now but there must be a solution
re installing starter essentials did not fix it.
the two morphs are Stephanie 5 and Stephanie curvy, manually dialing them out fixes figures
I looked in Data etc, cannot find anything
log file was
: Loading Startup Scene : N:/DAZ 3D/content/People/Genesis/Genesis.duf
*** Scene Cleared ***
File loaded in 0 min 4.4 sec.
Loaded file: Genesis.duf
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: FBMStephanie5.dsf
Loaded file: FBMStephanie5CurvyBody.dsf
Loaded file: FHMStephanie5HeadB.dsf
Asset : Scripts/Utilities/Lost_n_Found.dse could not be located
now is after re saving zeroed Genesis.duf
File loaded in 0 min 2.5 sec.
  • wancowwancow Posts: 2,708
    sounds like you reset the base morph file so it's on. I would suggest you un-install S5 and re-install her.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,489
    uninstalling her worked, now re-downloading her as I cannot find where I stuck her installer (have lots of dongles)
    yes all fixed now
    thx Wancaw
    Hope I do not do it agian!
    I forget what I did, but I ran into a similar problem once... re-instraling fixed the issue...
    When are you going to uprade to D|S anyway? :P
  • murgatroyd314murgatroyd314 Posts: 1,569
    edited April 2013
    Manual fix:
    Locate the offending morph file (e.g. My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 5/FBMStephanie5CurvyBody.dsf)
    Open it in a text editor.
    (If it's gibberish, rename it to .zip, unzip it, rename the resulting file to .dsf, and open that one.)
    Find the line that says "value" : 1, (or possibly some other nonzero value)
    Change the 1 to a 0. Make sure you don't do anything to the space before the number, or the comma after it.
    Save.
    Post edited by murgatroyd314 on
    thx, will remember that if it happens again
