Good refraction setting for water...
wancowwancow Posts: 2,708
hey all... I'm making a water image just for SnGs...
Using a cube for the water refraction... any suggestions on what to use for a refraction setting, and any other things you can suggest? The cube is not the surface of the water, I made a special plane for that...
3Delight render...
I'll be putting the cube below the main surface, at least that's the idea...
483 x 603 - 49K
  • Eustace ScrubbEustace Scrubb Posts: 2,687
    edited April 2013
    Index of Refraction for water is sometimes listed as 1.33346 at 0º C, but I don't know if that's simply fresh water, or distilled. At 100º C it is 1.31766. Or take a look at the Wikipedia page: http://en.wikipedia.org/wiki/Optical_properties_of_water_and_ice
    I also would NOT advise using a separate surface from your refraction, especially if you have waves or ripples that would normally lens the light.
    Post edited by Eustace Scrubb on
  • BWSmanBWSman Posts: 0
    Index of Refraction for water is 1.3330 at 20 degrees C (or 68 degrees F).
  • Richard HaseltineRichard Haseltine Posts: 97,131
    I assume there's going to be something in the scene to refract?
