Daz Studio HeadLight Simulator script
BlackFeather1973BlackFeather1973 Posts: 739
edited March 2013 in Freebies
This Daz Studio script adds a light to your current view that simulates the preview headlight and sets all your other lights to invisible. This will allow you to quickly inspect your shaders, bump and displacement maps with a fast 3Delight spot render. (the Daz preview headlight will not render when you have lights in your scene, this one will).
Run the script again to remove the headlight (if it's added to your perspective view it won't show up in the scene tab). [strike]You will need to turn your other lights back on manually with the eye icon in the scene tab.[/strike]
The intensity is a bit higher than the Daz headlight. If you want to change that the code is already in the script, just uncomment the marked line.
With thanks to cwichura for the idea
http://www.sharecg.com/v/68065/view/8/Script/HeadLight-Simulator-for-Daz-Studio
Update 18-03-2013 : Running the script again to remove the headlight simulator now also turns your other lights back on.
I have no idea why my brain didn't include that from the start :P
Post edited by BlackFeather1973 on
  • MelanieLMelanieL Posts: 7,865
    This sounds really useful, thanks - Just one question: does it work for UberEnv lights as well as "ordinary" ones?
  • BlackFeather1973BlackFeather1973 Posts: 739
    Yes, it works for UberEnvironment lights too. The script basically turns off everything that has a light icon in the scene tab and then parents a standard distant light to your current view. I also updated the script to turn on the lights again on the second run.
