African Village Kit script problem
daveleitzdaveleitz Posts: 459
I bought the African Village Kit by AM yesterday and installed it. I read the pdf tutorial and tried to run the !createvillage script by double clicking on it. Nothing happened. I tried executing it in the Scripting tab and got:
Executing Script...
Script Error: Line 90
TypeError: Result of expression 'getSelectedContentPath()' [undefined] is not an object.
Stack Trace:
()@:90
Error executing script on line: 90
Script executed in 0 secs 10 msecs.
I can load things into my scene manually. I can assemble the high-res huts manually, but the automated script for high-res huts doesn't work either.
I'm running DS4.5 64bit, Windows 7 64 bit. All content is installed to the default location in my documents folder. All four African Village installers have been run, and as far as I can tell everything is accounted for.
  • Richard HaseltineRichard Haseltine Posts: 111,340
    edited March 2013
    I see the same - probably down to the change from the Content pane to the Content Library pane, which has changed the way that folders are reported (since there's no guarantee there will be a defined "current content folder". Since the script is encrypted I can't poke around to see how it might be fixed - please open a support ticket or make a bug report.
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,659
    Executing Script...
    Stack Trace:
    ()@:90
    Hi, sorry for the issue. If you go to this link: http://www.alessandromastronardi.com/african-village-replacement-dsa-files-for-daz-studio/
    you will find the replacement script files and instructions to make African Village running on Studio 4.5.
    To note that I didn't encrypt files this time.
    Let me know if this works for you. Thanks.
  • daveleitzdaveleitz Posts: 459
    edited March 2013
    Thank you! I have downloaded the file. When I get home, I will try it out and let you know tomorrow. If this works, should I close the support ticket?
    Post edited by daveleitz on
    I think I will be able to support you directly.
    BTW, you may contact me directly at info_at_alessandromastronardi.com (replace _at_ with @ )
    Alessandro, that did the trick! Thanks so much for your help! :)
  • joramabbasjoramabbas Posts: 45
    I've had issues with this script!!!!!!!!!
    I moved from PC to MAC...MAC to PC..... No luck
    I downloaded new scripts till I used all my downloads with nothing working.
    Very pissed off with this vendor!!!!!!!!!!!!!!!!!!!!!!!!
    Some of us try to support the community by buying your scripts, and not nicking them from Piratebay, etc.
    Please, don't sell products to the public when faulty!!!!!!!!!!!!
    Very Angry Customer
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
    I've got nothing but good things to say about this vendor. He replied with a fix very quickly as anyone can see. I didn't have to wait for DAZ to upload a fix and then download and reinstall the whole thing. Joramabbas, it is not clear from your post whether you are having issues with the original download or with the fixed script.
    Yes I did and did exactly what it said but I get these errors :
    I also have issues of looking for this script in folders.....
    Regards
    1392 x 811 - 153K
    1269 x 718 - 142K
    I would be happy to help, but I'm at my work computer now, so I don't have access to DAZ Studio. Have you PM'd Alessandro?
    I use a MAc at work and PC at home.
    I'm at work right now...
    I'll try the same thing on a PC and give you feedback
    Have you moved the files within the Runtime\Libraries\Props folder?
    Very Angry Customer
    "Just in case", you can't really use all your downloads up. From your "Itemized Order History" list, you can reset them ;-)
    If it's not too late, here is something that can help:
    There you go folks, here the updated scripts for both DS 4.6 (that anyway should already be there if you updated through the DIM), and Poser 2014. I'll send these last to DAZ as well, so that they can update the installers again for the Poser side as well.
    DAZ Studio scripts: http://www.alessandromastronardi.com/AfricanVillage/AF_DS4.6_scripts.zip
    Poser 2014 scripts: http://www.alessandromastronardi.com/AfricanVillage/AF_Poser2014_scripts.zip
    Poser folks, just unzip and overwrite in the product Runtime:Python:AM:AfricanVillage
    Thanks and sorry for the issues. If you want you can reach me directly at "[email protected]"
