Genesis Problem: Left Thigh Bending Weirdly
Rohan101Rohan101 Posts: 0
Hi
I hope somebody can help me here, I have searched the forum but it does not seem like anybody else is having this problem.
I don't know quite how to explain this, however when bending the left leg on genesis i get some weird distortion on the thigh.
Tho\is was not always the case. It also only happens on the left side.
I have attached a picture of the problem I am having.
Any Advice would be greatly apreciated.
Thanks in advance
Rohan
639 x 637 - 29K
    When you first load Genesis, go to the Parameters pane, and select 'Currently Used'.
    That will show you if Genesis is using another morph when loaded. If so, dial it back to zero, and save the Genesis.duf file again
  • Rohan101Rohan101 Posts: 0
    Thanks a Mill. That led me to the solution.
    Really apreciate the assistance.
  • edited December 1969
    This is the exact problem I'm having and I don't know exactly when it started.
    When I check "Currently Used" after loading Genesis, it is blank.
    Any ideas?
    Thanks.
  • ImagoImago Posts: 5,698
    edited August 2014
    *EDIT*
    Forget it, I just solved the problem.
    Post edited by Imago on
