160 material preset for mcjTeleblender ( Blender Cycles ) for DS 1, 2, 3, 4
mCasualmCasual Posts: 4,607
edited February 2013 in Freebies
download page -->https://sites.google.com/site/mcasualsdazscripts2/mcjtbmatspack1
all those presets are based on variiations of
Diffuse Color hue and intensity
Specular Color hue and intensity
sometimes the specular color is white, sometimes it;s the same hue as the diffuse color
the presence of a random image on the Reflection Color channel determines ig the surface will be glossy or mirror'y
1474 x 818 - 394K
1474 x 818 - 412K
1474 x 818 - 411K
1474 x 818 - 352K
1474 x 818 - 313K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    that's the default daz studio material rendered in Blender cycles
    the second one uses one of the "sharp" material presets
    637 x 637 - 436K
    364 x 364 - 25K
  • nakamuram002nakamuram002 Posts: 813
    Got them and will try them out, thanks Casual!!
    Are the shaders designed to work with the "standard" mcjTeleblender, or is the "mcjMakeCyclesNodes_MIX_instead_of_ADD" patch needed?
    it uses the new one with "mix"
    in teleblender i used gloss factor = 0.1 and rough=0.1
    the drawback is that it made Aiko's skin way too oily
    but i could fix this in part by darkening the Specular Color intensity
    i could use rough = 0.25 , and it would not change the mirror/sharp materials much
    720 x 720 - 650K
    720 x 720 - 98K
    1280 x 720 - 884K
