Script which has stopped working
HeraHera Posts: 1,970
Hi!
I have a lovely V4 character called LeeLo, but her head morph script does not work anymore. I've pasted it here, if there's any wizard out there who have a clue...
Script is placed in Runtime\libraries\AM-Morph
Code removed
  • HeraHera Posts: 1,970
    I don't get any error messages or anything, the script just don't do anything anymore
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Unless it's your own character you shouldn't post the morph deltas on a forum - though the post didn't actually hold all of them anyway. Before I deleted it it looked as if the channel name was custom, a pose can't add a channel but only change the content. Try reposting, but leave out all the deltas (the lines with just numbers).
    Sorry, that was a bit too technical for me.
    What I want is the bits like this:
      channels
       targetGeom somename
        name someothername
        interpStyleLocked 0
        deltaAddDelta 1.000000
        indexes 996
        numbDeltas 1279
    This is what it starts like, before it's followed by and endless row with d:s and numbers
    version
    number 4.01
    actor head:1
    channels
    targetGeom PBMCC_01
    name Leloo
    forceLimits 1
    min -100000
    max 100000
    trackingScale 0.02
    keys
    static 0
    k 0 1
    interpStyleLocked 0
    indexes 12287
    numbDeltas 15078
    deltas
    OK, so it is using one of the standard channels. Is this Poser or DS? If it's DS, and if you get the Power Loader dialogue box when opening V4, make sure you have the Legacy Injection Channels option checked.
    edited January 2013
    Legacy Injection Channels ?
    I have something called Legacy INJection Slots, is that the same?
    Because that one is toggled, and it doesn't seem to help
    Post edited by Hera on
    Still need help with this
    edited February 2013
    When you first load V4, the big popup box that appears is called the Power Loader ... and there's a little box to check so it will add the Legacy Injection Channel. [I don't have this on my laptop, if this is saying slots, then yes it's the same thing]
    If you don't have the Power Loader, check your available downloads or reset the downloads for V4 to get it, and run that installer. Open D/S and try again.
    However it was that the files for the product were packaged, keep to that. If you've moved files around, they probably won't work because they can't find each other. And they wouldn't give an error message.
    The script may be here: Script is placed in Runtime\libraries\AM-Morph, but that's not where it's loaded from. There should be a pose file for it that loads the morph.
    Post edited by patience55 on
    Can that be the error then, that I'm missing the Legacy Injection Channels in the power loader?
    Because in poses, there's Leloo-Complete.pz2 - which calls
    readScript ":Runtime:Libraries:AM-Morph:injLeloo-head.pz2"
    figure
    defaultPick BODY
    and later
    readScript ":Runtime:Libraries:AM-Morph:showLeloo-head.pz2"
    Both those scripts are available at Runtime\libraries\AM-Morph
    None of the files have been move from their original position related to each other
    Those files place the data for the character in the injection channels, but they can't create the channels which is why you need them enabled when you load V4.
    And that is I suppose what I wonder how to do
    Assuming you use PowerLoader:
    485 x 548 - 44K
    I do, and I have that one toggled, still the script do not work
    Then I don't really have any ideas, I'm afraid.
    Assuming that since it worked and now, nothing major was changed, the next idea that comes to mind is if there's another script that has also been added that is overwriting this one possibly if the 2 are using the same channel.
    Might be an idea to reinstall the morph too in case somehow it was corrupted.
