Simple railings with quayside/urban/park (new/old/repaint) colour schemes [More railings!]
3dcheapskate3dcheapskate Posts: 2,728
edited February 2013 in Freebies
Uploaded to ShareCG and Renderosity FreeStuff as 'Railings01' (don't forget the Morphing Railing Add On)
Second set of railings (different style) also available - see later in this thread.
A set of four simple railing props for Poser and DAZ Studio that can be connected together to form a variety of larger railings by simply parenting Y rotating, and X/Z translating.
Three colour schemes (quayside, park, and urban)
and three 'ages' (new, old, and repaint).
The 'old' variants use a very simple shader to combine the rust and paint in accordance with a simple mask image (in DS there are a two extra parameters on the 'Surfaces' tab under 'Diffuse' for this - see the second promo image for more information)
The ZIP contains THREE main folders: Runtime, Runtime (Extra DS Files), and DS Content. Poser users only need the first, DS users need all three. See the readme for more details.
(The basic constituents are PP2 prop files and MC6 material collections, with PZ2 MAT pose files for those who prefer them. But I've included DSA material presets, and modified material presets, so that if you load the props or apply the MAT poses in DAZ Studio they'll automatically load the correct DS material)
Happy rendering!
500 x 500 - 369K
Post edited by 3dcheapskate on
  • 3dcheapskate3dcheapskate Posts: 2,728
    edited January 2013
    Here's the simple shader I used (Poser version).
    The DAZ Studio Shader-Mixer-generated version is more-or-less the same, but I've put the main parameters onto the surfaces tab (and kept all the usual ones!). So you don't need to open shader mixer to change paint colour, rust coverage, etc.
    1670 x 930 - 338K
    Excellent props, and a lot of work went into these, thank you very much.
    It is great to see something like this with shaders for both Poser and DAZ Studio, thanks again for taking the time to do it.
    My pleasure - it was fun creating them! I'm a 50/50 Poser/DAZ Studio user, so I like trying to make stuff that works equally well in both.
    By the way, I spotted a little problem with the design: you can't use these railings on a slope, or around a curve...
    But the fix should be quite simple, just a couple of morphs in the PP2s.
    I've started work on the morphs, and I'll post back here when the fix is ready.
    Morphs too :)
    Thank you, that will be interesting.
    edited January 2013
    After trying various approaches I'm going for a separate 'Morphing Rail Section' (or something like that) prop that looks identical to the existing 'Pillar And Rails' prop when it loads, i.e. a single pillar with three rails sticking out of the side. The only change from the 'Pillar And Rails' is that I've added a couple of extra edge loops near the ends of each rail, and I've added some morphs to bend the rails in a few different ways (e.g. Slope Up, Offset Left, Bend Right 90).
    I'm more-or-less happy with it now - just testing and putting together some rules-of-thumb for using different morphs together
    Anyway, here's where I'm up to - attached image shows six 'Morphing Rail Sections' with different morphs applied, translated and rotated to roughly fit together (three renders of the same railing from different viewpoints). Hmmm... adds another dimension to the railings, literally!
    386 x 555 - 58K
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    When will the updates be available?
    Testing seems fine (not perfect, but good enough I think). Finalizing the rules of thumb for combining morphs now. Release should be later today (it's 10am here).
    edited January 2013
    Morphing Railing uploaded separately to ShareCG and Rendo Freestuff.
    Rules Of Thumb For Using Multiple Morphs Together
    1) Slope morphs should work okay together with either Offset or Bend morphs, although the rails may look a bit flattened from some angles. You shouldn't need to use the correction morphs.
    2) Shorten-Extend should work okay with Slope or Offset or Bend morphs, but you'll need to use a Correction morph as well:
    - with a Slope morph, you'll need to set Vertical Correction to about the same value* as Shorten-Extend
    - with an Offset or Bend 90 morph, you'll need to set Horizontal Correction to about the same value* as Shorten-Extend
    - with a Bend 45 morph, you'll need to set Horizontal Correction to about HALF the value* of Shorten-Extend
    * Same sign for Offset/Bend Right or Slope Up, opposite sign for Offset/Bend Left or Slope Down.
    3) If you follow these rules of thumb and it still doesn't look right, fiddle with the correction morphs until it does!
    500 x 500 - 76K
  • shaaeliashaaelia Posts: 613
    Thank you, these look fantastic and will come in so handy. :-)
    Thanks, I'll try it a bit later on.
    It is a great addition to the set.
  • SpitSpit Posts: 2,342
    Thank you. The morphs make it exceedingly useful. I don't think I've run across any type of fencing that has that capability. Kudos!
    edited January 2013
    Nice to know people are finding them useful - in fact, that's enough incentive for me to try making an alternative set, still a WIP at present.
    Note: for these test renders I applied Smooth Polys (Poser) / SubD (DAZ Studio). The railing's not yet UV mapped so I've just set diffuse and specular colours and added a procedural 'Clouds' texture to the bump channel - that's all.
    426 x 479 - 58K
    Railings02
    Second set of railings are now available on ShareCG and Renderosity Freestuff. Same principle as the first set but I've tried a slightly different approach to the Rail Adjustment morphs. I've also included a 'Single Rail' prop to give an alternative way of making railings. More info on the ShareCG page (and in the readme if you download).
    The textures are procedural, so no texture images included (although everything's UV mapped and there's a texture template included). The steel cable shader is quite temperamental, but with a bit of fiddling it can look quite good - the render in this post was done in DS3 using the shader in the freebie (plus that post gives a bit more info about the shader).
    496 x 496 - 50K
  • nDelphinDelphi Posts: 1,939
    edited November 2013
    Railings02
    Thank you for this. I used two single railings as steel cables for a construction crane tower in my current art scene.
    Post edited by nDelphi on
