to determine the button is pressed or not pressed
YudinEd
Hi!
How can I determine the button is pressed (clicked, released) or not pressed (not clicked, not released) with help of script?
Post edited by YudinEd on
Hi!
You need to create a function to handle button presses and use the Connect function to link it to the clicked() signal for the button - which is emitted when the button is presed and released. The function could do whatever you want, from simply setting a variable to indicate that the press occured to reconfiguring the dialogue or data state. http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/language_reference/signals_slots/start
Hi, Richard Haseltine!
I'm glad you answered me.
I understand sense, but unfortunately badly I know the script syntax. How to link the letters into a single whole :)
A small script example would help me ( even untested).
I'm trying to do it:
Button is pressed (finger on the button ) and I have an infinite action. The button is released (remove your finger from the button) - action stops
So I have 2 strings
I think that correctly understand the logic -
if true (button pressed) then function myPressedFunction
else (false) then function myReleasedFunction.
I tried different variants (I will not give examples, so you do not laugh ), but I could not keep track when removed finger from the button - the action does not stop.
Please little exаmple . Thank you in advance
I think you need something to keep the incremnts happening separate from the button actions - I added a DzTime (using the code snippet from the Connect documentation in the DS3 docs as a starting point and this seems to work:
Timer!
It is a good idea and works perfectly. My thanks.
