the old flogged to death obj and FBX export subject
WendyLuvsCatz
once again I am finding extremely annoying export issues with UV mapping and textures to other apps on some sets.
and have no easy answers just more questions
the latest PITA is Powerage's Old Town Bordeaux.
I finally got it as all one obj into Carrara and unticked UV wrap in the vertex room and it mapped correctly but a damned big obj with many maps.
duf and other options failed badly
In Poser and iClone no luck.
Increasingly DAZ products are not only D|S only but it seems you cannot even export a useable obj to other applications.
I am not blaming the PA's as they make them to work in D|S as required and they do fine, its a D|S export issue.
The plugins need more options to cover stuff like UV wrap on x and z axis etc and D|S badly needs a texture bake option for procedural iray and 3Delight shaders that will use either renderer to render a texture baked to the model's UV for use in other apps.
my video in Carrara after a hellava lot of fluffing around!
below how it loads in Poser, iClone the same
Actually, the Wavefront|Alias OBJ format is very straightforward, simple, and pretty easy to implement an importer or exporter for.
The problem is various OTHER entities keep trying to extend it to add in additional data/parts/etc. to bring it forward into the 21st century. The Wavefront OBJ format is quite old.
Everytime one place extends it, another importer breaks. Their export no longer matches the standard. While it should technically just ignore anything it doesn't support, that doesn't always work.
I feel as though its a duf format issue as the uv unwrap issue occurs with duf files from Studio in Carrara too, Poser used obj or pp2 or obz I only have this issue with some duf only files, a reimport of the obj into D|S has the same issues I might add.
I must add an important note here
99% of exports are fine!!!
its mainly Stonemason and a few other PA's products such as this Powerage set that do it.
What is worrying is its becoming more frequent with new content.
As someone who use to convert a lot of models from one format to another, (MAX, LWO & 3DS to OBJ) I can tell you from experiance that its not always the mesh but how the parent program allows shaders and textures to be used on any given surface. Because we build our models for use in Daz Studio, Iray and 3Delight become governing factors in what we do. There are things that can be done in those two engines that work great for those engines but dont work for any other render engine. The same is true for Poser's Material Room. Presets saved out from it that can do wonders in Poser do not work at all in Daz Studio.
So what you are experiancing is nothing new or unique. Its the bane of all those who wish to convert from one format to another or take a model from its "native" application to a different one. Think of it like languages. Your native language works great in your home country but not so much, or at all, in another.
