A Shader Builder Tutorial for the Beginner using DAZ Studio 4.5 and Mike King's Gooch shader languag
DollyGirlDollyGirl Posts: 2,709
Merry Christmas and Happy Holidays!
I would like to present to you a Shader Builder Tutorial for DAZ Studio 4.5. This is a beginner's tutorial, that is, this tutorial assumes you have little to no experience with the Builder and leads you through the process of creating, building and accessing a shader for DAZ using an exsisting shader language script. For the tutorial I have used Mike King's Gooch shader. The tutorial is in pdf format, Also included in the zip file are the preset files (in duf, dsa and sdl formats) of the created block. My small gift to those that have given to me. Hope it is informative. If there are issues please tell me. I too am new to this that is why there is minimal technogeek in the tutorial. Looking forward to seeing people create some cool shaders.
Lonnie
Access the tutorial here:
http://www.sharecg.com/v/66014/browse/3/PDF-Tutorial/DAZ-4.5-Shader-Builder-Tutorial---MK-Gooch-Shader
700 x 700 - 563K
    Good job on the tut and nice work on the shader and presets.
  • DollyGirlDollyGirl Posts: 2,709
    thanks mjc. I needed to solidify my learnings from the summer and this is how I did it. I give thanks to Takeo.Kensei for giuding me through the tougher parts of this learning.
  • HibernatusHibernatus Posts: 19
    Great! The second most useful D|S 4 tutorial I have seen (the first was one who taught me how to make that new interface usable :-))!
    Thank you. I thought my trials and troubles should be put to good use. Hopefully this is not so simple that it becomes a waste of time.
  • ReDaveReDave Posts: 815
    edited December 2012
    I haven't read it all but it's a very nice tutorial! I guess I can stop porting posts for the Shader Builder sticky from the old forum (besides the spherical camera shader doesn't work anymore in DS4).
    Post edited by ReDave on
    Thank you. It is a start. Nothing to serious, but it might ease someone's frustation with the fact that documentation for this feature is very sparse indeed.
  • BlackFeather1973BlackFeather1973 Posts: 739
    Thank you so much for this tutorial.
    Going through it now, wish i had found it earlier... :)
    BlackFeather, Your welcome. Hope to see your results. I used the tutorial myself to get Stephen H Westin's velvet shader created. It worked! So I hope that you are successful too.
    800 x 1317 - 919K
    Great job on the velvet shader, it looks fantastic !
    I'm just learning the basics of shader mixer/builder. Still a long way to go, it gets complicated quite fast. Your tutorial is a big help !
  • letseyletsey Posts: 2
    looks like the tutorial was taken down,, needs reposted plzz!!
  • KharmaKharma Posts: 3,214
    Lonnie
    Does anyone know if this tutorial is still available I get an error that says the page can't be loaded...thanks
  • The tut is removed...  wtf? :(
  • mikael-aronssonmikael-aronsson Posts: 599
    edited October 2015
    I have the file, not sure if it is ok to redistribute it though (downloaded it long time ago)... have to check
    Ok, I checked the readme file and it's ok to put it up for download, I have put it at:
    http://rustandmagic.se/ShaderTutorial.zip
    It will stay there until end of the month (2015-10-30) so grab it there if you need it, it's about 2 megs.
    Mikael
    Post edited by mikael-aronsson on
  • atticanneatticanne Posts: 3,009
    Mikael
    Thanks for reposting this tut for us, Mikael.
  • I have the file, not sure if it is ok to redistribute it though (downloaded it long time ago)... have to check
    Mikael
    Thnks , I'll have a look at it asap
    Cheers
  • PendraiaPendraia Posts: 3,631
    Thanks...this looks useful.
    Ws anyone else able to download the script file and RIspec file that is listed at the beginning of the tutorial?  the links don't work for me
    I am glad you are interested in playiing with the Shader Builder but do realize that I pulled the tutorial down for a reason. You can however, find the information that the tutorial is referencing with a little work.
    I googled the RISpec 3.2 manual and found the document here:
    https://renderman.pixar.com/products/rispec/rispec_pdf/RISpec3_2.pdf
    I used the wayback machine to find the link to Mike King's script file here:
    https://web.archive.org/web/20130126052841/http://www.renderman.org/RMR/Shaders/MKShaders/index.html
