smart content does not work (valid postgreSQL in question?)
Hi I have just installed DAZ studio4.9 with all my content with the install manager
It has been installed in the recommanded folder (to selected path) see attached screen capture.
nothing appear in the library (but a few Poser content)
nothing in the smart content
I have this error message about a non valid postgreSQL
what is it? any body can help?
thanks
Dom
1280 x 950 - 106K
  • fixmypcmikefixmypcmike Posts: 19,718
    What OS and security software are you using?  Did you install PostgreSQL CMS before the content?
  • HogyoHogyo Posts: 59
    Windows vista no security
    I have never heard of PostgreSQL CMS
    where do you find it?
    thanks for answering
    It should appear in DIM -- it's a separate install package from the main Daz Studio package.
    Hi I just found that according to install manager PostGreSQL (for 64 ) was installed.
    my PC is x64
    so where is the problem?
    What does DS show in Edit > Preferences > CMS?
    it shows roaming/DAZ 3D/cms
    port 17237
    I have checked the cms folder is present where expected..
    If you go to that folder, does cmscfg.json show the same path and port?
    Thanks for your time.
    What do you means it does not show anything to me!
    Do you have that file?  If you open it in a text editor it should have the path and port number being used.
    I have desinstalled and reinstalled this cms
    there is a slight improvement, but no file to be found!
    see the screen capture
    1119 x 707 - 78K
    I don't understand what you mean it does not show anything to me!
    I have desinstalled and reinstalled the cms, there is a slight improvement bur still no file to be found
    see attach
    1119 x 707 - 78K
    Okay, it looks like there are leftover copies of each item pointing to an incorrect location.  Go to the Content Library pane and click on the icon with 3 horizontal lines in the upper corner of the pane > "Scan Known Direrctories for Files".  That should clear out the invalid entries.
    Hi
    thanks
    It first cause Daz 3D to collapse! but then when I reboot it seems to do the job
    I'll let you knoww.
  • inquireinquire Posts: 2,458
    http://www.daz3d.com/forums/discussion/69878/install-studio-4-9-on-mac-get-error-a-valid-postgresql-cms-connection-could-not-be-established/p3
    There is a situation like this for Macintosh users. You might want to look at the above thread. Various situations are discussed. I realize you are on Windows, not a Mac, but still . . .
    There's also this, from the DAZ help desk, that may help: https://helpdaz.zendesk.com/hc/en-us/articles/207812393-PostgreSQL-Connection-Error-and-No-Smart-Content
