[Released] Turbo Loader for Genesis and Genesis 2 [Commercial]
RiverSoft ArtRiverSoft Art Posts: 6,778
Do you have a large content library? Have you started to dread loading a Genesis or Genesis 2 figure because it can take so long? Then the Turbo Loader for Genesis and Genesis 2 is for you! Turbo Loader turbocharges Daz Studio for users with large content libraries. By disabling unneeded morphs for your Genesis and Genesis 2 figures, see dramatic speed increases in loading scenes and figures, and even clearing scenes.
The first time that Daz Studio loads a Genesis, Genesis 2 Female, or Genesis 2 Male in a scene, Daz Studio searches your content directories for all the morphs used by that figure and creates properties to control them. With a large content library with lots of morphs, this operation can take a long time. However, for most scenes, you don't need all of those morphs.
The Turbo Loader scripts detect ALL morphs in your system for Genesis, Genesis 2 Female, or Genesis 2 Male and organizes them by product. Turbo Loader will work with morphs installed manually, by Daz Install Manager, or even by Daz Connect!
Disable all the morphs for a figure type (except some important products such as Genesis 2 Starter Essentials). Then, quickly enable select morphs for the scene you want to create. You will be amazed at how much more responsive Daz Studio is!
  • Turbocharge the loading of figures* and scenes.
  • Finds morphs, properties, and aliases wherever they are located, even in multiple locations such as products installed with Daz Connect.
  • Organizes morphs by product, allowing you to easily enable and disable morphs to suit your current needs.
  • Create configurations to quickly and easily enable or disable sets of morphs before loading figures.
Products installed manually or with products like Content Wizard do not have morphs recognized by the Daz Studio database. They will be organized as unknown products with a name from their parent directory.
*This is very dependent on the number of morphs you have for a figure generation. In tests, we have seen speed increases from 5-12x faster!
Post edited by RiverSoft Art on
  • RiverSoft ArtRiverSoft Art Posts: 6,778
    And it is released!
  • Your description says G, G2M, and G2F, but the screenshots show all the way up to G8.1 figures. So... are those sorted as well?
  • NorthOf45NorthOf45 Posts: 5,687
    No. A couple of the utilities are shared, like Turbo Loader Configurations and Turbo Loader Scene Configuration, so if you have the G3/G8 versions, any configurations you have created will show up in the list.
    edited May 2022
    @NorthOf45 is correct (thanks for the help!).  This product is for Genesis and Genesis 2 only.  There is another product for G3 and one for G8/8.1.
    The Turbo Loader Configurations can use configurations saved by any of the TL products.  Turbo Loader Scene Configuration scans a scene and just records the used morphs for Genesis through Genesis 8.1.
    Apologies. I had no idea the previous products existed. Somehow their releases totally went past me. Perhaps my library wasn't annoying enough back then, but you certainly have my attention now.
    No problem.  Probably my main promo was not catchy enough to snag your attention! smiley  There are support threads for each of the TL products (and one for the just announced Turbo Loader Booster Utilities)
    Submitted update today:
    • Updated RSTurboLoaderConstants.dsa file for Turbo Loader for Genesis 9 support
    • Modified getting selected assets in Turbo Loader Scene Configuration to ask which you want to use, if both Smart Content and Content Library panes are visible and have selected assets
    • Changed GetFilesFromDir function so that the function ignores symbolic links
