i setup new daz but i can't find send to unreal
我不知道该怎么办,我很焦虑
please
Answer me
thanks
  • Richard HaseltineRichard Haseltine Posts: 107,911
    There is an issue in 4.20.0.2 with saving the UI layout (on systems without existign saves) and this seems to eba ffecting the isntalaltion of the Bridges. There is a workaround here v , after which try installing the Bridge again.
  • 理查德·哈塞尔廷说道:
    在4.20.0.2保存UI布局时有一个问题(在没有现有保存的系统上),这似乎影响了桥的安装。这里有一个变通办法,在此之后,尝试再次安装桥。
    thanks Thank you. I've solved that problem.
  • NetsuraiNetsurai Posts: 2
    I had the same problem and was able to solve it, see picture attached
    Window - Workspace - Update and Merge Menus
    667 x 451 - 72K
