resetting head morphs back to figure head default?
ToobisToobis Posts: 993
So I am playing round with a bunch of face morphs for a G8 figure but I messed up how I wanted it to look so I wanted to just simply revert back to the default head morph I loaded her into the scene with. How can I do this please.
  • duckbombduckbomb Posts: 585
    Usually I just select the head, right-click in the "Scene" pane, select all children, and then click on that little icon near the universal tool gizmo and click "Restore selected items pose".
    If that doesn't work, though, it's because there's a morph that's also loaded at the same time.  So, restore to default pose like I mentioned above, and then go into your parameters tab, select "currently used" and see if you can identify which morph is the culprit.
  • ToobisToobis Posts: 993
    any chance you could screenshot your steps here? sowwie :(
    Shoot sorry, no, I'm on my work machine.  I can do that later, probably, but right now I don't have access to DS.
    Yeh when possible I'd appreciate that thanks.
  • November 2021: me, too.
  • margravemargrave Posts: 1,822
    The automated way:
    Edit -> Figure -> Zero -> Zero Figure Shape. The head morph is just a preset. Reapply it from the figure's product.
    The manual way:
    Select the figure in the scene tree, hit the "Currently Used" option in the properties pane, and then scroll through the list and alt-click on every morph except the head shape to reset it.
