Has there ever been a new Version of DaztoUnity Bridge or is v1.0.1 the only one?
The only version i've always had since in installed Daz To unity bridge about 1 or close to 1 year ago, is version 1.0.1, then recently i logged in to see if there would be a new version by now because iit's been a long time i would think they updated the thing, and having things like the default Skin from daz characters being set to UberSpec instead of UberSkin which is always the case no matter what i do, i thought mm....maybe DazToUnity bridge has had an updte and downloading and installing it would solve my prob lem. Yet i see that there hasn't been an update like i said since about 1 year ago. Or am i wrong? Is there a version 2 or something that i'm missing somewhere?
When i use DAZCentral, the only version that has always been there is 1.0.1?
I am thinking. Maybe i need to setup some settings in DAZStudio, in order for DAz3d/Iray/UberSkin to be selected for the skin shader in Unity?
Is that what i need to do? And if so, what settings do i change? Cause all my skin is getting translated to UberSpec and i just dont like that, i always end up just having to change it to UberSkin, so what's the point of having it set to UberSpec
I left a possible solution and explanation on one of the first threads you posted regarding IrayUberSpec being assigned instead of IrayUberSkin:
https://www.daz3d.com/forums/discussion/508936/has-there-been-a-reason-given-by-daz-unity-as-to-why-the-default-daztounitybridge-shader-not-skin#latest
The short answer is: make sure "Iray Uber" is the shader material being used for your figure in Daz Studio. Good luck!
