October Carrara Challenge WIP Thread: Create a pulp magazine cover with Chills, Thrills, & Carrara S
18911131421
  • HeadwaxHeadwax Posts: 10,385
    Oh I think I will keep them :) Even Russians have Ослепительная Истории, в конце концов, они изобрели Спутник :)
  • pimpypimpy Posts: 274
    понятно!
  • sukyLsukyL Posts: 251
    edited October 2014
    pimpy said:
    Hi sukyL,
    I tried the same tutorial but I did not get the result I wanted.
    In an underwater scene I tried it with a spot on the water surface and two shape ligth. the result looks good to me. for the fog in my scene, the distance is less than what you have posted and the color is not black .... the only thing is to try ....
    I have included these images and the setting of the lights and the fog....:)
    pimpy Thanks so much for sharing the screen caps and settings of your underwater scene! It looks great and definitely has a very convincing effect of watery depths.
    Post edited by sukyL on
  • AntaraAntara Posts: 444
    edited October 2014
    Google translate is getting good, but not entirely correct :). I loved your use of Cyrillics for that very reason (not Google translate getting good, but Russians inventing the Sputnik) - it immediately added the whole new layer of the cold war and the cosmic exploration rivalry, and the real historic references and context to the very fictional publication, publishing fictional stories.
    Post edited by Antara on
    edited October 2014
    Sorry, double post.
    pimpy , Antara :) Oh I did a sputnik image a while back and happily found that when I typed in my Cyrillic font that Sputnik came out correctly - very interesting :)
    thank you Antara btw - sorry I havent been around, as you said, you blink and the thread has raced off several pages! which is great :)
  • DiomedeDiomede Posts: 15,388
    This month's theme is Rankin and Bass claymation, right? :red:
    I'm glad there is still a lot of time left.
    513 x 513 - 235K
    1480 x 1973 - 104K
    1480 x 1973 - 157K
    I like that you know where you are going I can easily see this turning out to look like the bottom right pic :)
    edited October 2014
    Great stuff. Pimpy, I really like the new cover!
    Well, I was hoping to have a completed test render by the time I got home, but one of my network nodes crashed. I didn't lose anything as I could pause the render and re-launch Carrara. Well, actually I did lose something- Time. The render wasn't nearly as far along as I had hoped due to two processors not doing anything.
    Here's a partial screen capture of what I have. My only problem is that I must have done something to the astronaut's key light and I don't know what it was. I'm just not happy with the light on his upper torso and skull. I may add a light and restrict it to the skull and upper torso.
    I did add the reflected light and I'm pretty happy with it. I also made the little red things on the moss glow and added a bulb to the replicators for them, which is really killing my render time as the moss is Carrara's dynamic hair. I may exclude the hair from the lights and then put a shape light above the moss and restrict it to the hair. One light will render faster than hundreds.
    1022 x 746 - 1M
  • DustRiderDustRider Posts: 2,879
    Well, as I suspected might be the case, the final render is running now ..... again >:(
    I found a bit of poke through on the shorts that I had completely missed! Sure, it would be easy to fix with Gimp, but then my whole idea of no post work would be, well, ... a grand idea that didn't work. Of course I could have just left it there, and hoped nobody noticed, but I couldn't do that either.
    Soooo.... below is a nearly final render, with the text in it's final position (I hope). I converted all of the text to vertex models to make it easier to "fine tune". I also included a close up image showing the great details in the outfit/shaders. This was captured at greater than 100% scale (about 200%), I really like how Octane Renders scale up so well. This was also the image where I noticed the dreaded poke through!!!
    One of the other images below is of the Time Machine rendered in Octane with the materials that came with it ..... yuk!!! It looked just as bad rendered in Carrara. I used some of the shaders from the Octane LiveDB as a starting point for "fixing" the shaders on the time machine.
    The other image below is of the current scene set up in Carrara.
    1000 x 1000 - 148K
    1204 x 883 - 318K
    1546 x 2000 - 721K
    981 x 922 - 162K
  • booksbydavidbooksbydavid Posts: 429
    Well, I was hoping to have a completed test render by the time I got home, but one f my network crashed. I didn't lose anything as I could pause the render and re-launch Carrara. Well, actually I did lose something- Time. The render wasn't nearly as far along as I had hoped due to two processors not doing anything.
    Looking very good! Keep at it.
    On the light for the astronaut, I've had that happen to me before as well. I'm wondering if you had a 'point at' modifier set for that light. Sometimes the 'point at' modifier goes wonky on me and stops pointing were I told it to. You might just want to delete that light and replace it with a new one. I've almost pulled my hair out trying to figure out what causes this when it happens.
    Hey, I like Rankin and Bass animation. :)
    And I never knew Flash Gordon worked for Union Carbide.
    I added a low intensity shape light and restricted it to the skull and head covering, so I'll see what happens. Probably tomorrow as it is way past my bedtime.
  • StezzaStezza Posts: 8,734
    These WiPs are the ToPs
    Such detail by everyone... that is a cool time machine dustrider :-)
    I've been messing around with this one ... nowhere near completed and may not be but getting it out there anyways..
    Made the raygun and remapped, boned and tried to fix up the martian
    Keep 'em coming ak ak ak ak
    532 x 727 - 47K
    666 x 479 - 42K
    Love it! The diversity of rayguns and rocketships is tremendous. And that is one cool looking Martian texture.
    Well, I've done about as much damage as I can to my final image, so I'm stopping before it's too late. :)
    Hopefully these will all show up in the right order.
    The first image is the raw Carrara render. I quite liked it, but I'm never satisfied so off to the postwork factory it went.
    In the second image I added a glow effect behind my 'queen' character in Paintshop Pro. I did have a glow attached to a bulb light behind her, but it didn't render, so I added it here. I also added some condensation and escaping air to the broken space helmet to increase the danger to our hero. The plant creature wasn't menacing enough, so I did some reconstructive surgery on him. I especially like the new dental work. I gave the shadows and highlights a bit of help in a few places and I also painted a glow for the two tubes on top of the ray gun. I never saw them until I rendered the final image. I must have tube blindness. :)
    The next image shows the result after a trip to Onone software's Perfect Effects. I probably used a dozen filters to get the look I was after.
    The fourth image contains the titles. I tried to avoid this step until the very end because I'm usually pretty lousy at titles. It turned out better than I imagined.
    The fifth image is another case of 'I just couldn't leave it alone'. I decided I wanted a more antique look, so I headed back to Perfect Effects and ran it through one of its 'vintage' filters to get a more 'aged' look.
    I'm not even going to think about doing a second image. One's enough.
    800 x 1035 - 512K
    800 x 1035 - 432K
    800 x 1035 - 428K
    800 x 1035 - 298K
    800 x 1035 - 299K
    Yes, one cool Martian, and the raygun is a perfect pulp raygun.
    Thanks for the encouragement, Headwax and BooksbyDavid. For the detective, I made the eyes and the hair, did a test render, and freaked out when I realized how much it looked like a character from the Mad Monster Party instead of a pulp figure. Maybe I should step away from that project for a while and return with fresh eyes. Where did I put that alien biker project?
    The reason Ming was merciless was because Flash was a pushy salesman.
    That is a beautiful render. One is definitely not enough. We want more, more, more!
    :lol:
    Thanks, but definitely enough...for now. (Heh, heh)
    ha ha books bydavid - you are tukewlforwerds - love it. you did a fine job on the postwork, ads zing just the right amount
    Stezza, if I was a Martian I want to be one of yours - especially of I get a gun like that :)
    Dustrider, that's a beautiful clean render
    Heh, heh. Thanks. :)
  • TangoAlphaTangoAlpha Posts: 4,586
    Gosh, you lot have been busy overnight! I only had a quick scan, or I'll be late for work!
    I've tweaked mine slightly, changing the shaders on the girl's outfit, and adding a pin spot just to highlight her face better. Oh, and I changed some of the gags on the cover ;)
    1113 x 1440 - 2M
    edited October 2014
    Classic work Tim-A , what a crack up :)
    Here's some quick test renders from me, Cyborg Vicki and her son Ralph
    The three without text are straight renders. The Vickii Cyborg is made with two Vickis, one inside the other, the innards exposed by transmaps on the top Vicki
    1556 x 2000 - 650K
    1386 x 2000 - 667K
    640 x 900 - 391K
    640 x 900 - 324K
    Post edited by Headwax on
    edited October 2014
    diomede I love Rankin and Bass too! There is nothing wrong with your figures. They have the right look. You just need to free yourself from a static, literal placement of the figures to one that's more dramatic. Take license and play with space and proportion.You just need to arrange, resize, and emphasize what you want to tell your story even if it doesn't actually make sense in reality. I think the effect will be much more pleasing to you. Check out your desired example. The female character is huge in the forground with the male character much smaller doing something in the background. This lobby card for the actual movie is a composite of characters which is non-literal, but the use of relative size gives dramatic emphasis to Sam Spade, Mr. Cairo, and the falcon to tell the story.
    220 x 221 - 125K
    Wow! Great composition booksbydavid. Very well done!
    Thanks. :) It was fun.
    Like the changes. Love the humor.
