Way to Remove All Textures?
FauvistFauvist Posts: 2,288
I'm having trouble with some characters eyes in DAZ Studio (on a Mac - which shouldn't matter in this case).  Some of my character's have have GenX generations mixed in them and have geo-grafted bodyparts so I can used skin textures made for other generations.
Is there some way I can remove ALL textures from an eye?  Without having to go into all the slider settings for each part of the eye - cornea, iris, etc.?  So I can just apply a new eye texture.
  • LeanaLeana Posts: 12,888
    Apply the base shader again to the eye surfaces maybe?
  • juvesatrianijuvesatriani Posts: 561
    edited July 2021
    If you`re using G8 0r G8.1 figuresyou can make your own BLANK  preset via
    1.loading (figure) DEV LOAD .
    2.Make sure select your DEV LOAD figure selected in scene tab.
    3.Then GO to surface tab and select all eyes material and with all selected save as Material Preset . When Pop up windows open , Untick everything unless Eyes part . Click OK
    Same rule if you already have favorite eyes setup . just load character with eyes setting you like .  Then Repeat 2 and 3 step
    Here I`ve included EYES NO map material preset  for G8 and G8.1 . *Female and Male figures using same material structures )
    HOW TO USE : After you load your custom texture from other generation /geograph etc/ just apply this preset . ( Without CTRL +CLICK)
    duf
    duf
    G8 Eyes NO MAP.duf
    53K
    duf
    duf
    G81 EYES NO MAP.duf
    62K
    Post edited by juvesatriani on
  • nonesuch00nonesuch00 Posts: 18,795
    Select the Cornea, Sclera, Pupil, Iris, Eye Moisture in turn and manually remove the textures (or just apply the grey base shader in the Genesis Essentials as Leana says) and then save a "Eye Blanker" Materials Preset just for those selected surfaces.
  • McGyverMcGyver Posts: 7,085
    edited July 2021
    I was initially thinking this was about "all textures in a scene", not specifically the eyes...
    It would be super useful to have a "Clay Render" option in Studio.
    Lots of other software seem to have that... I always forget to mention that in those "Next Version" suggestion threads...
    There is probably a plugin or something for that... I think I saw one a long time ago.
    Post edited by McGyver on
