• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…20212223242526…49»
  • siocsioc Posts: 326
    September 2014 edited September 2014
    empty
    Post edited by sioc on September 2014
  • mCasualmCasual Posts: 4,607
    September 2014 edited December 1969
    sioc said:
    sure :
    thanks, i found the issue
    in fact it was difficult to reproduce that error
    for an unknown reason, apparently, your bump map was not exported by the obj/mtl exporter
    mcjTeleBlender saw the bump map in your scene, and "sent a message" to
    mcjBlendBot like "set the bump map strength of surface X material Y to the strength Z
    and mcjBlendBot being over-confident in the existence of surface X material Y
    told Blender to do the impossible, and it all went crashing
    in the next the version posted, mcjBlendBot will look for the existence of the surface before asking Blender to do something to it
    mcjBlendBot UPDATE mcjBlendBot UPDATE mcjBlendBot UPDATE mcjBlendBot UPDATE
    for cases where bump map exports fail
    2014 September 15 11:22 PM - Version 3.04 beta - mcjBlendBot will not attempt to adjust the
    bump map strength of materials for which no bump map exists. Note that the mcjTeleblender script was updated earlier today,
    Post edited by mCasual on September 2014
    sioc said:
    if you remove the bump map from that material
    you should be able to see the normal map and avoid the error
    No more bump map so the trouble is elsewhere... :(
    Just a wild guess -- maybe the filename V4C_MAT_RIBBED_NML.jpg or the path to this image is causing problems
    so you could try renaming it rib.jpg and place it in a simple location like c:\users\temp or the Maps folder
    it could even be a case of uppercase/lowercase in the filename that prevents blender from finding the file
    also, sometimes Daz Studio speaks about .jpg files when the file on disk is actually a bmp or png
    I confirm no more that bump error :)
  • HellKoreaHellKorea Posts: 17
    Hello Casual..
    There is Scale issue.
    Camera and lights position is different when i change the scale.
    Thank you always. you're a Genius.
    1332 x 839 - 374K
    jerrycrow said:
    Hello Casual..
    thanks i located the problem
    just a matter of moving 1 line of code
    it will be fixed in the next update
    only the daz script will need the update
    About Cycles choice, could you add the tiles size in the settings before export ?
  • ladagaladaga Posts: 4
    A casual hello to me it would be very convenient to use two buttons.
    Export and one frame of the animation.
    I really like your plugin, if it just remake using standard DAZ Export obj&mdd; would be very cool!
    I found a way to add the entire scene. You and so much to create one in order to make it all good.
    Only here there are some difficulties with the opening .Keep vert order no is the default.
    http://www.youtube.com/watch?v=Ke_t88FNkWk&feature=youtu.be
    1920 x 1080 - 1M
    yes in the next version/update mcjBlendBot will turn on the [keep vertex order ] option of the obj importer
    concerning mdd - i will post a small C-Language program and the .exe that converts a series of obj files into a single-group obj file and the mdd. The mdd-writer already works but i converted the .obj to mono-group using wordpad.
    The good part of this .exe is that it will work with .obj sequences from DAz Studio, Carrara, Poser, Blender, etc...
    and mcjTeleBlender can use/launch this program right after exporting the obj sequence
    then mcjTeleBlender/mcjBlendBot can open the mono-group .obj file in blender, build the cycles material and even apply the MDD file as the object modifier
    someday if i make a live-link / bridge between DS and Blender, i will probably use this
    for Mac compatibility j could have the objs-to-mdd converter be a blender-python script ... i don't think it will be as fast
    next version will have - tile sizes , which in fact works for Cycles and non-cycles renders
    the default setting is to let Blender use its current default settings
    the other settings range from 16x16 to 1024x1024 ( powers of 2 )
    960 x 960 - 135K
    1920 x 1080 - 420K
    empty
    empty
    sioc said:
    I somehow found the trouble but how to fix it ...
    I pushed the normal map to 6 and I could see my normal map effect. So it was here but the surface doesn't show the right thing in blender.
    To have it right I had to open and reselect : Diffuse BSDF, then that made appear Normal map, then by reselecting normal map I could see image texture and there it is!!
    Is there a way to refresh the proprieties so they show correctly ?
    i still suspect that there's an issue with this specific filename or the path
    you could try using the jpg image shown below
    another distant possibility is that the normal map dimension in pixels is too gigantenormous
    1024 x 1024 - 106K
    i will wait before adding the "Keep vertex order" option because it removes all the groups, and mcjTeleBlender/mcjBlendBot needs the groups
    the program i wrote to generate MDD from a series of obj file will also create a no-groups obj file, and mcjBlendBot will be able to import it
    next update will have the cameras and light positions properly sized when the meshes are using an export ''Scale' different than 1%
    here the Daz Studio scene with Aiko3 was exported with a scale of 10%
    Once in Blender i added a default cube, which is 2 meters wide, and it's the same size as the cube which was 20 cm wide in Daz Studio
    ' fig 2 - exported at the default scale of 1%
    so the default Blender cube which is 2 meters wide looks 2m wide
    960 x 960 - 136K
    960 x 960 - 126K
    empty
    empty
    sioc said:
    I saved your normal map as normal.jpg in c:\tmp and replace the one used by yours and the trouble in the parameters display is the same.
    To be sure in a new empty scene I created a primitive cube 1m x 1m I added your normal map still in c:\tmp and exported it : same result the normal map is working BUT the proprieties are saying :
    you have to expand the Diffuse and Glossy nodes to see the normal maps
    842 x 734 - 320K
    I feel really stupid...
    Thanks and sorry :)
    PS: I'll clean up my latest post that are uninteresting
    Update - 3.05 - Update - 3.05 - Update - 3.05 - Update - 3.05 beta
    >>>>>>>>> https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    mcjTeleBlender and mcjBlendBot
    2014 September 16 4:50 PM - Version 3.05 beta -
    mcjTeleBlender now scales the camera and light positions using the same scale factor as the mesh export
    mcjTeleBlender and mcjBlendBot now transmit the render tile size ( which can in some cases speed up renders )
    1920 x 1080 - 420K
  • SzarkSzark Posts: 10,634
    Thanks and sorry :)
    hey it is better than looking stupid like me. :)
    Casual this is progressing really nicely...I can't wait to play some more but I am holding off until you are finished. Have I ever thanked you for making this for free, in the spirit of Blender and all the hard work you do for us.
    Do you have any advice to have less fireflies in the render ?
    Szark said:
    Thanks and sorry :)
    i want to get back to mcjBuilder to add the new stairs to the mcjCastle which will also have animatable doors
    so probably i'll write mcjTeleBlender3's manual, iron out a few quirks, then declare it out of Beta, and into uhh gamma testing
    which is a very handy and vague term
    the other project i hope to get time for this autumn is a Kinect plugin or something
    oh and with mcjBuilder ... this gothic'like movie set
    1920 x 1080 - 542K
    try using Clamp Indirect in the render settings pallet, start around 0.80 - 3.00 but it does depend how much glossy surfaces you have and if you are using Caustics. There is a Caustic disable function in the render settings pallet too.
    Casual said:
    Szark said:
    Thanks and sorry :)
    cool. I think Blender Cycles has gamma correction enabled at default.
    there's more fireflies when there are few small lights,
    so if your scene allows it, try removing walls and use a "World" with or without Environment map
    and make the other lights large
    also try reducing the number of glossy surfaces that are not really needed since they produce small light sources
    and the caustics should normally be turned off
    adding a bit of ambient color ( say 5% white in the Daz Studio surface ) can also help hide the ''noise''
    there's also a filter setting in the render settings panel but i didnt learn to use it
    you can also try filtering the render result using photoshop or Blender's layer compositing post processing
    videos ! yay ! https://www.youtube.com/results?search_query=blender+cycles+reduce+fireflies
    MDD support for mcjTeleBlender/mcjBlendBot coming this fall
    ( possibly at least initially, only for PC-Windows and Linux )
    up til now, mcjteleblender lets you render animations by exporting each frame as an .obj file
    then rendering the 30 frames by running Blender in invisible mode
    there's a file format named MDD, it treats the scene as one big mesh,
    the mdd file is like one huge collection of morphs, with 1 morph per frame
    as long as your scene content is not too complex and as long as the animation is not too long
    it should fit in the memory of a modern PC
    and Blender will be under your control, not running on autopilot
    so you could create animation loops in Daz Studio, and integrate that in your Blender movies
    320 x 320 - 1M
  • ben98120000ben98120000 Posts: 469
    Set min and max light bounces to the same value.
    hi casual~
    i found another scale problem.
    it's bump value (and normal?).
    if scale 1% export >> bump value 0.005,
    scale 2% export >> bump value same as scale 1%(0.005 not 0.010)
    am I wrong? check please~
    (sorry my bad english)
    Thanks always.
    Post edited by HellKorea on September 2014
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
