Losing Smart Content / Products / Categories Data Constantly
I can't tell you how many times I've had to go through that process (documented in the Help area) to restore my product folder content. The database seems to be so easily screwed up.
Sometimes my macbook pro will go to sleep, and won't wake up. I'll have to power it off. If DAZ is up when that happens, occasionally, it comes back with all the content gone from the product and category areas. I've worked so hard to organize Poser & DAZ content into those categories.
I've made backup copies of the DAZ folder where the content management databases are, but now I find I can't get a recovery even with that. I'm going to have to uninstall and re-install DAZ and the DIM program again.
Anyone else getting content grief?
Are you sure the database is actually being corrupted? It does happen, way more frequently than it should to some people, but a much more common glitch is that the CMS (content management service) which reads the database has simply stopped. If that's what happens to you, then you might not need to toss out your old database and start again. Have you tried closing D|S and turning the CMS back on again? Does it make any difference if you restart your computer? (I just noticed you're on a Mac, I'm not sure how you get at the CMS start/stop controls as they're very different from Windows. You might have to wait for a Mac user to spot this thread.)
Greetings,
To start and stop the DAZ Content Management Service, you want:
In the directory /Library/DAZ 3D/Content Management Service/vlogs you will find the Valentina logs. Some are small, and contain stuff like:
Some are long, and contain long repeated intervals of:
The latter kind of file probably means it's corrupted. I have no idea what the errors in the first kind of file mean.
-- Morgan
