2013 PA Giveaway!
189101214
  • TrishTrish Posts: 2,625
    Thank you very much everyone has really made my Christmas Special this year !!...Trish
    Zev0 said:
    It won't work on Genesis1. It's HD geometry is specific to G2M EG saved on the G2M mesh. And because the polycount is different, cannot work on Genesis1. So the problem is not UV related, but mesh related.
    (---- what he said. It'll work with any g2M skin but it does have to be on g2m.
  • Knight22179Knight22179 Posts: 1,195
    Unfortunate
  • FistyFisty Posts: 3,416
    hmm.. Load a Genesis 2, set its UVs to M5. Export it out as an obj, I would suggest at 3 times sub-d (yes, there's a reason)
    Load the veins morph, make sure the sub-d level is the same, export the object again with a different name.
    Get x-normal, it's free. Load the regular G2 as the low rez object and the G2 with veins as the high rez. Generate height map (displacement) or a normal map, your choice. Normals give cleaner results in the final render but displacement is adjustable.
  • barbultbarbult Posts: 26,163
    Karth said:
    barbult said:
    Day 9 - 17December
    His EarStuff from Karth
    http://www.daz3d.com/new-releases/his-earstuff
    Thank you for this unique jewelry. I've figured out almost everything about how to use it, but I can't figure out how to get the LoopAddL and LoopAddR to move into position inside the HisStuffLoop on M6. The HisStuffLoop has a morph to move it to fit M6, but the LoopAdd items do not have any morphs. I tried moving the LoopAdd items with the X,Y, Z translate, but that didn't work very well. Do you have any tips?
    The Loops have material presets, but the AddLoop items do not. However, I was able to figure out how to use the UniShaders to color them. So now if I can just get them moved inside the loops, everything will be perfect!
    Sorry that you have problems
    Select the LoopAdd and go to surface room.Make sure you have select a material.
    After that you can choose your any shader i add to the package. Go to Smart Content ..Shaders..Earstuff.
    I have upload a fix position morph
    You can download that here:
    Fix Add Loop M6
    Thanks for the new morph. It is working great.
    1000 x 800 - 306K
    In this wild array of pattern and texture, several new PA freebies appear. Thank you for the gifts.
    2000 x 1500 - 3M
  • DestinysGardenDestinysGarden Posts: 2,553
    Got Light?
    Day 15 - 23December
    InaneGlory's Lights and Lamps Xtra by InaneGlory
    http://www.daz3d.com/new-releases/inaneglory-s-lights-and-lamps-xtra
    349 x 455 - 29K
    edited December 2013
    Very nice Barbult! Those textures look especially good on the dress.
    Post edited by DestinysGarden on
  • DisparateDreamerDisparateDreamer Posts: 2,520
    Thanks to ALL the vendors for their wonderful freebies and generosity!!! I'm a bit behind on giving thanks... and haven't gotten every freebie (i missed a couple) but ALL are totally appreciated and I am greatly thankful for the wonderful gifts and the super vendors!!!!
  • SylvanSylvan Posts: 2,719
    Nice, the lamps are setup to work in Lux!
    Thanks for all the freebies <3</p>
    zigraphix said:
    atryeu said:
    Thanks for the camera info. I didn't know if there was a special step in there or not so it's nice to hear it's used like a regular camera :)
    Custom cameras in DS are really very easy to use. They haven't been that easy to create until recently, though. I really like the variety of different custom cameras we're starting to see now. I highly recommend Age of Armour's Atmospheric Effects, for example. There are lots of options for those who like to tweak settings, but also lots of presets for out-of-the-box fun. :lol:
    Thanks for the SketchCam! :coolsmile:
    689 x 631 - 199K
    Post edited by Knight22179 on
  • IndigoJansonIndigoJanson Posts: 1,100
    Many thanks for the latest gifts! Much appreciated.
  • IppotamusIppotamus Posts: 1,580
    http://www.daz3d.com/new-releases/inaneglory-s-falloff-studio is also a Christmas present for owners of Photo Studio 1, 2, 3!?
    I put it in my cart and the price changed to $0.00
    Reading the description, it is also a Christmas item it seems. XD
    Thanks soOOoo much InaneGlory.
    You are aces.
    I can not wait to play with these new presets.
    Post edited by Ippotamus on
    Ippotamus said:
    http://www.daz3d.com/new-releases/inaneglory-s-falloff-studio is also a Christmas present!?
    You are aces.
    I quote from the Product Page
    This product is free for purchasers (or owners) of Photo Studio 1, 2 or 3, Photo Studio Lux or the Photo Studio Bundle.
    Post edited by Chohole on
    You are aces.
    Ah makes sense that the price didn't change until I went to the cart.
    It also makes sense it is only for people who have purchased one of the Photo Studio releases ... ... applying those presets to that forgotten hat in the corner of my runtime could prove to be rather time consuming :)
    Thanks for reading the fine print Chohole. ;)
  • sapatsapat Posts: 1,735
    Ok, clearly I had some free time today and couldn't resist playing.
    Xmas 2013 pressies:
    FWDarc from FWArt
    SunHair from Fisty
    SketchCamBasic and ToonCamBasic both from Zigraphix
    I used the SSS Mats that came with Darc for the renders. My lighting (Sunlight for DS by Vince Bagna at RDNA) may have been a bit too bright for the toon and sketch cams, so I need to experiment more. I just wanted to get these posted before the holidays were over and I still had a bit of free time here and there.
    My thanks to all the contributors as always. :cheese:
    Click on each image for a less squished view!
    800 x 1000 - 181K
    640 x 800 - 150K
    640 x 800 - 162K
  • MelanieLMelanieL Posts: 7,714
    You are aces.
    Really glad I called in to the forum again this evening or I might have missed this. Thanks for drawing it to our attention.
    And a big THANK YOU to InaneGlory for not one but TWO freebies today! (I own all three Photostudios, just not the Lux one)
  • Mari-AnneMari-Anne Posts: 363
    You are aces.
    Thank you to Ippotamus for posting this. I thought I had missed out on the gift since it didn't show $0.00 for me.
    Also, thank you to InaneGlory for the generous gift!
  • InaneGloryInaneGlory Posts: 294
    Sorry about all the confusion everybody. The Falloff Studio didn't get set up the way it was supposed to have been when we planned it. Hopefully it is all working as it should now. The Falloff Studio was supposed to be MY personal gift to MY customers, while the Lights & Lamps freebie was more of a community-wide gift.
    The Falloff Studio is supposed to be free to anyone who has purchased one of the following products:
    InaneGlory's Photo Studio
    InaneGlory's Photo Studio 2
    InaneGlory's Photo Studio 3
    InaneGlory's Photo Studio Lux
    InaneGlory's Photo Studio Bundle
    - honestly, it's not of any value to anyone who doesn't have one of these products. The price should drop to $0 when you put it in your cart. If it's not please contact customer service or PM me. The original plan was that the Falloff Studio would stay in the store and that anyone who had purchased one of the required products before the end of 2013 would be eligible to get the Falloff Studio for free, not just free during the next three days.
    Happy Holidays everyone!
    500 x 651 - 212K
    Xmas 2013 pressies:
    FWDarc from FWArt
    SunHair from Fisty
    Cool!
    Thank you! :)
    Merry Christmas!
    773 x 1000 - 432K
    Day 16 - 24December
    Belly Control For Genesis 2 Male(s) by Zev0
    http://www.daz3d.com/new-releases/belly-control-for-genesis-2-male-s-m6
    350 x 455 - 42K
  • gabugabu Posts: 303
    what is this sketchcambasic that is being mentioned?
    I can't find it listed anywhere
  • Milo_471560Milo_471560 Posts: 511
    http://www.daz3d.com/december-freebies/camera-magic-tooncam-basic it was up when I wrote this. Not sure when it comes down.
    http://www.daz3d.com/december-freebies (shows those still up)
    Ah! so sketchcambasic is the same as tooncambasic?
    No wonder I couldn't find it
    No, the two cameras are different products. SketchCam was given away earlier in the month. I think it's 3 days of availability have expired. Sorry.
  • Alethas FantasyAlethas Fantasy Posts: 0
    I'd like to Thank Zev0 & ARTCollaborations for the Merry Christmas Freebie for Poser also, Today.
    I do appreciate them, Have a Very Merry Christmas! :) :) :)
    Thank you all, that's great somebody still makes freebies. It keeps the hobbyists alive!
    And dumb question time: what is the last day of this giveaway? The 24th (Christmas Eve) or the 25th (Christmas Morning)? I have some kind of a fuzzy feeling DAZ itself is preparing something for a grand ending... What are your opinions?
  • kyoto kidkyoto kid Posts: 41,838
    ...Zev0, thank you.
    This has been one of the best if not the best Holiday giveaways ever.
    Thank you all.
    Post edited by kyoto kid on
