The Can't Fix Stupid STUPID THREAD VII
1313234363750
  • JaderailJaderail Posts: 0
    and then we have...
    499 x 415 - 258K
    560 x 350 - 243K
    800 x 485 - 431K
    450 x 338 - 124K
  • kyoto kidkyoto kid Posts: 41,839
    edited July 2013
    ...Catruday already? Crikey the week went by fast.
    499 x 397 - 50K
    480 x 360 - 52K
    Post edited by kyoto kid on
  • TJohnTJohn Posts: 11,339
    Caturday stuff...
    (Warning: post may contain some dog)
    620 x 484 - 86K
    449 x 337 - 72K
    499 x 374 - 157K
    499 x 555 - 83K
    393 x 511 - 34K
    I can relate to that last one, Happens most mornings.
    Some more
    500 x 376 - 51K
    700 x 545 - 26K
  • TSasha SmithTSasha Smith Posts: 27,236
    It is caturday and I want to check out some lolcats
    ...morning (stretch, ouch).
    500 x 340 - 40K
    I am cold but I am dressed warmly.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,014
    find somebody to cuddle.
    one the other hand...
    680 x 569 - 117K
    500 x 714 - 94K
    450 x 336 - 33K
    500 x 479 - 46K
    565 x 598 - 40K
    edited July 2013
    500 x 375 - 34K
    Post edited by Chohole on
    Thanks for all the lolcats!
    chohole said:
    As mentioned before, i bread my cat, but I didn't get any kittens. :D
    The real Puss-In-Boots.
    554 x 445 - 32K
    My internet is acting up. Sometimes it works but other times it does not
    'Scaturday.
    600 x 660 - 59K
    620 x 934 - 84K
    620 x 465 - 33K
    599 x 464 - 76K
    530 x 577 - 48K
    Keep coming with the LOLcats! They are so cute and fun!
    Hmm... naw...
    500 x 374 - 25K
    500 x 315 - 22K
    640 x 544 - 72K
    I forgot to add this pic to my Brother's Birthday vid
    http://www.youtube.com/watch?v=CLWOOOZKlGM
    Jaderail might think of a caption!
    674 x 703 - 114K
    another, same floral shirt (it WAS the 60's!!!)
    572 x 300 - 45K
    edited July 2013
    so I did...
    572 x 300 - 101K
    674 x 703 - 215K
    Post edited by Jaderail on
    Another stupid attempt to post this image.
    1518 x 938 - 274K
    edited July 2013
    No cats but too squeeable not to share.
    The ducklings were hatched in an incubator and imprinted on the family dog as their mother. : )
    480 x 643 - 57K
    Post edited by TJohn on
    The cats come back.
    533 x 426 - 181K
    620 x 930 - 85K
    554 x 408 - 53K
    276 x 362 - 21K
    620 x 463 - 63K
    ...now that is both sweet & cool.
    LOVE!! Ducky Dog! So cute... now this...
    500 x 458 - 63K
    700 x 691 - 183K
    772 x 726 - 54K
    450 x 326 - 33K
    edited July 2013
    This has to rate an inclusion in the stupid thread, even if it is a bit late for Caturday
    http://www.youtube.com/watch?v=iMzgl0nFj3s
    If that link won't work for you, try this one
    http://www.youtube.com/watch?v=UJN80qZQ1P8
    TOOLS AND HOW TO USE THEM
    SKIL SAW:
    A portable cutting tool used to make boards too short .
    BELT SANDER:
    An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs .
    WIRE WHEEL:
    Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh s**it' .
    DRILL PRESS:
    A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it .
    CHANNEL LOCKS:
    Used to round off bolt heads . Sometimes used in the creation of blood-blisters .
    HACKSAW:
    One of a family of cutting tools built on the Ouija board principle . . . It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes .
    VISE-GRIPS:
    Generally used after pliers to completely round off bolt heads . If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand .
    OXYACETYLENE TORCH:
    Used almost entirely for igniting various flammable objects in your shop and creating a fire . Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race .
    TABLE SAW:
    A large stationary power tool commonly used to launch wood projectiles for testing wall integrity .
    Very effective for digit removal !!
    HYDRAULIC FLOOR JACK:
    Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper .
    BAND SAW:
    A large stationary power saw primarily used by most shops to cut large pieces into smaller pieces that more easily fit into the trash after you cut on the inside of the line instead of the outside edge .
    TWO-TON ENGINE HOIST:
    A tool for testing the maximum tensile strength of all the crap you forgot to disconnect .
    PHILLIPS SCREWDRIVER:
    Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads .
    STRAIGHT SCREWDRIVER:
    A tool for opening paint cans . Sometimes used to convert common slotted screws into non-removable screws and butchering your palms .
    PRY BAR:
    A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part .
    PVC PIPE CUTTER:
    A tool used to make plastic pipe too short .
    HAMMER:
    Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit .
    UTILITY KNIFE:
    Used to open and slice through the contents of cardboard cartons delivered to your front door . Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts . Especially useful for slicing work clothes, but only while in use .
    These can also be used to initiate a trip to the emergency room so a doctor can sew up the damage.
    SON OF A BITCH TOOL:
    Any handy tool that you grab and throw across the garage while yelling 'Son of a bitch' at the top of your lungs . It is also, most often, the next tool that you will need .
    edited July 2013
    THE SOCKET SET AND RATCHET:
    an assortment of hexagonal shaped receptacles lying at the bottom of your tool drawer that do not fit any bolt or nut, being either too small or loose and a little levered device to fit them in with a gear you alwaystwist the wrong way so you tighten said nut or bolt even more rounding the poorly fitting edges ensuring no spanner will undo it even if it fits.
    Hence the name, bloody ratshit thing!
    JIGSAW:
    A device for fitting little serrated blades in, you poke into a predrilled hole to embed itself part way once you start to cut, get very hot and snap off and make you dance a jig with your sore finger in mouth.
    CLAW HAMMER
    a device for hammering nails in crooked then pulling their heads off.
    ANGLE GRINDER
    a device for showering yourself with sparkles of hot metal.
    CABLE TIES
    handy little plastic things for holding your car together or anything else that can endanger your life when they melt and snap
    DUCT TAPE
    see above
    CHEWING GUM
    see above
    TWISTY TIES
    see above
    OLD PANTY HOSE
    see above
    Jade said I had missed this one
    HAND HELD POWER DRILL::
    Most often used to drill straight holes into Items at angles that line up to nothing.
    Also usfull for adding extra holes to tabletops and other surfaces that do not require a hole.
    edited July 2013
    NAIL GUN
    device for firing nails with compressed air through your finger into the rafter on top of you pergola where no-one can reach easily to help you.
    BOW SAW:
    as name suggests you bow sore for days after using this to cut boughs
