[Released] EcVh0's Iray Skin Shader for Genesis 8 Male
EcVh0
With the new release of the new Iray engine, and the new Genesis 8 Male figures, EcVh0 has returned for another stunning product!
Introducing EcVh0 Iray Skin Shader for Genesis 8 Male(s)!
Better than ever before, thanks to the upgraded render engine, these shaders achieve the greatest and the most realistic effect on ANY Genesis 8 Male(s) character's skin!
One click
- Without having to know anything in depth on rendering skins
- Without having to look for appropriate light sets
- Without having to face the light source
- Without having to look for presets for your skin to suit the light condition
- Without having to do tons of post-editing
Your character will no longer be flat under any light conditions from single light source to sun-sky environment to HDRI maps and more!
Great, yes I do use pale skin characters, sometimes I succeed, sometimes I struggle, I will give it a try. I will come back and say how I get on.
Hello IcVh)
OK, I have purchased this, the new translucency map works fine, and the option to remove facial and chest hair, if required, is usefull.
However the fact that no matter what the character has bright red gens hair kills it stone dead as far as I am concerned.
Maybe I am wrong, have I missed something?
If I am right, can this be revised, is a "remove gens hair" a possibilty? With red gens hair on it is totally inflexible.
Regards
Are you refering the bright red gen hair on the torso area (without an additional gen geo) or from the gen shader (on addition gen geo)?
I can surely have a look and get rid of the gen hair for you, or do you simply want it less red? :)
Hello,
I bought this skin shader, but even if it's very real you can't remove facial, abdomen, genitalia and legs hair. After all I buy a skin shader not a skin + hair shader ;-)
Maybe i'im wrong or i don't know how but is there a way to remove all the hair ?
Thanks you
Helllo!
You can find them in the extra option folder
I believe currently we only have remove eyebrow and remove chest hair option... unfortunately...
But if you really need those hairs to be removed, I could grab you a few maps you could use
, also you could try moving M8's skin map onto the translucency slot to see if it would work
