Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
How do I do that with a preset?
In the LAMH group you will see the surfaces that contain hairs listed. Hide those surfaces that you don't want calculated (use the "eye" visibility marker).
Kendall
I want to know too....please respond.
Nope you don't, the updates are specifically designed for use with the Catalyzer
Thank you.
Using LAMH in 3DL, if I change the shader used on the hair/fur, is there a way to lock that in so it doesn't reset the next time you load the scene?
I noticed that in the updated products which now have Catalyzer presets, the .lmh files have been removed. Is that intentional?
It's not needed since the information is all embedded in the .duf files.
Alessandro,
Your recent stuff has been as impressive as always but when are we going to get some more cute little furry animals?
Cheers,
Alex.
Can’t say for sure but not too far. What would you like to see first?
Dogs or cats
Dogs.
Mouse or Rat.
After struggling trying to make morphs for dogs (holy poo), dogs.
I had heard the mildog was 'old' but I didn't appreciate what that really meant.
Dogs. Maybe dogs. I'd even settle for domesticated canines, but really, dogs.
As a side note, I seem to remember something about convertimg some of the furrythings presets to catalizer, maybe that could help tide us over while we wait for updated models (of dogs)?
Possum, possum, possum. Pretty please . . . Brushtail Possum.
Need something cute for hunting scenes.
Alessandro,
Top of my wish list is the Red Panda. They are incredibly cute and adorable and I think they would sell very well. The success of the Bear Cubs and Squirrels shows that cute sells.
Cheers,
Alex.
Dog. Cat. Desperately desperately need a new updated dog or cat with LAMH: different breeds etc.
Also a new rat. My poor ol' noggins rat is showing his age - particularly if we can get some "fantasy" type colours for him.
Cat.
Note for my fellow dog lovers, CGNZ does a couple of add-ons for Alessandro's wolf mark two:
https://www.daz3d.com/husky-for-wolf-2-0-by-am
https://www.daz3d.com/german-shepherd-for-wolf-2-0-36965
These are not catalyzer compliant, however, so if you're also into Iray you'll have to render them the old-fashioned way.
Cheers,
Alex.
Ferret/ermine. Or otter. Maybe a pine marten?
A lynx :) But every animal is fine for me :D
DEFINITELY a lynx! But I'll take anything that has fur and a heartbeat...
So after you get a selection. How do you save a section as a preset so I dont have to select the area's everytime I load LAMH?
While in the LAMH editor you can save a .lmh file at any time that can be reloaded onto the same generation figure. All work that you've performed to that point will be saved.
Kendall
k, but your missing the point.. im aware its possible. im asking how.. :)
nvm.. it just dont work when i try to overwritte. it said not supported and aborts. i dont understand why. the only thing i can do is delete the object and re import it into the scene to get any loading presets to work. im probably doing something wrong, but i dont know what.
Overwriting presets already attached to the figure doesn't work. The only way that I have found to load a different preset onto a figure is to (1) close the LAMH editor, (2) delete the existing fur preset using the Scene tab, and then (3) select the base figure again and load a new preset. I will often save the scene and re-open Studio between steps 2 and 3 if the problem happens more than once. Hope it helps...
It is possible to merge presets, i.e. add new presets with the current one. However, this isn't supported from within the editor. At one point we had that feature working in the editor but a change in DS versions broke the feature so we had to disable it.
Kendall
